harness question -takata short version
Old Nov 25, 2006 | 05:34 PM
NMZ's Avatar
NMZ
Default harness question -takata short version
had a question about the takata short version and having a b pillar bar
is the takata supposed to be very short [shorter then usual] because i only looped it around the bar once. also are there diff eyebolts for diff cars ? ? can anyone post set ups of short version takatas and bars?
edit
where do they eyebolts go? is it the bolts behind the seats?
Modified by NMZ at 7:07 PM 11/25/2006
Modified by NMZ at 7:12 PM 11/25/2006
Old Nov 25, 2006 | 05:39 PM
Default Re: harness question -takata short version (NMZ)
you can get the eye bolts from HomeDepot..just get the right thread pattern.
they are not supposed to be hooked up to a B pillar bar for safety reasons. they should be attatched to a roll bar harness bar or cage harness bar
NMZ's Avatar
NMZ
Default Re: harness question -takata short version (vega_box)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vega_box &raquo;</TD></TR><TR><TD CLASS="quote">you can get the eye bolts from HomeDepot..just get the right thread pattern.
there are not supposed to be hooked up to a B pillar bar for safety reasons. they should be attatched to a roll bar harness bar or cage harness bar </TD></TR></TABLE>
yeah of course
but gotta improvise for now
im wearing both seatbelts incase the cops pull me over
Old Nov 25, 2006 | 05:41 PM
Nick M's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NMZ &raquo;</TD></TR><TR><TD CLASS="quote">
yeah of course
im wearing both seatbelts incase the cops pull me over </TD></TR></TABLE>
I wouldnt wear the harnesses until you get a rollbar.
Just use the normal seatbelt by itself.
Old Nov 25, 2006 | 06:13 PM
NMZ's Avatar
NMZ
Default Re: harness question -takata short version (Evil Nick M)
Old Nov 25, 2006 | 06:14 PM
.wtf's Avatar
in ca you can get a ticket for wearing the harness.
Old Nov 25, 2006 | 06:16 PM
NMZ's Avatar
NMZ
Default Re: harness question -takata short version (jdmRICER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmRICER &raquo;</TD></TR><TR><TD CLASS="quote">in ca you can get a ticket for wearing the harness. </TD></TR></TABLE>
can they still ticket if i wear both..and theyre both fia/dot approved
Old Nov 25, 2006 | 06:18 PM
depends on the cop
Old Nov 25, 2006 | 06:59 PM
why are you wearing both seat belts anyway??
Old Nov 25, 2006 | 07:40 PM
NMZ's Avatar
NMZ
bump guys
need help!
so these eyebolts should fit universally?
Old Nov 25, 2006 | 07:45 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NMZ &raquo;</TD></TR><TR><TD CLASS="quote">bump guys
need help!
take out your back seats, take out the bolts that hold down the seat belts in the rear, take that bolt to home depot and measure the bolt thread, take that measurement and go find eye bolts
Old Nov 25, 2006 | 07:48 PM
Airbag Club's Avatar
they are not supposed to be hooked up to a B pillar bar for safety reasons. they should be attatched to a roll bar harness bar or cage harness bar </TD></TR></TABLE>
you should be very careful if you plan to use home depot eyebolts.. you have to make sure that they have a certain hardness, because you won't not want them to snap on you in the event of an accident..
Old Nov 25, 2006 | 07:53 PM
NMZ's Avatar
NMZ
Default Re: harness question -takata short version (Airbag Club)
wait wait im confused
eyebolts from the rear seat belts?
i have the short version takatas
arent the eyebolts for the piece that goes to the waist? i was thinking they hooked behind the seats to those two bolts that hold the seat in place.
I HAVE the takata eyebolts but they do not fit into those holes so thats why im asking where they really go
Old Nov 25, 2006 | 08:11 PM
oh yeah disregard my statement then about them going to the back.
Old Nov 25, 2006 | 10:13 PM
NMZ's Avatar
NMZ
hm where does the eyebolts bolt up to where the seat bracket bolts?
Old Nov 25, 2006 | 10:30 PM
they bolt to where your seat belts bolt to.. for my lapbelt, i have one holding the seat belt buckle onto the rail, and the other to the bottom of the seat belt. the one to the bottom of the seat belt is a little tricky, but i used a thick piece of steel (which came with my used takatas) to relocate the eyebolt. the piece of steel is bolted down using the seat belt bolt, and the eyebolt is bolted to the steel piece. sorry it sounds really confusing, but there is no other way to describe this without pictures.
you can kinda see them here..
Old Nov 25, 2006 | 10:42 PM
NMZ's Avatar
NMZ
oh thanks airbag club
yeah i didnt know where to mount the lap belts. the eyebolts were way to fat for whre the bolt goes into the seat rail so i didnt know what was wrong
oh is yoru takata the long version btw?
Old Nov 26, 2006 | 12:04 AM
yeah they are the long version takata's. i took off the clips and wrapped them around the harness bar.. here is a before picture.
Old Nov 26, 2006 | 08:37 AM
NMZ's Avatar
NMZ
oh nice thanks
ok so right now my setup is like your after pic except it seems like the belts are SHORT? also the question still remains. where do those eyebolts go lol
i see youre using sidemounts right&gt;
Old Nov 26, 2006 | 09:19 AM
Default Re: (NMZ)
i already explained it up top...
lapbelts..
one eyebolt replaces the bolt that holds the seat belt buckle to the bracket.
the other eyebolt replaces the bolt that holds the bottom of the seat belt, near the door.
shoulder belts.. (short version meant for use with roll cage/harness bar, or for a convertible.. i.e. S2000)
eyebolts are to be mounted on frame (S2000) or welded to the roll cage/harness bar.
Old Nov 26, 2006 | 09:33 AM
NMZ's Avatar
NMZ
Default Re: (Airbag Club)
cool
ill go out in a min
Old Nov 26, 2006 | 09:57 AM
Default Re: (NMZ)
here are some pictures of the short version mounted..
Old Nov 26, 2006 | 10:27 AM
NMZ's Avatar
NMZ
oh WOW no wonder..
i also wrapped mine
Old Nov 26, 2006 | 10:32 AM
Default Re: (NMZ)
if you wrap them around the bar, you should take off the clip buckle parts, and use slide bars..
Old Nov 26, 2006 | 10:34 AM
should be wrapped like this..
http://www.schrothracing.com/info/2
