ITB Manifold cost
Old Nov 25, 2006 | 05:06 PM
K2e2vin's Avatar
Default ITB Manifold cost
About how much does it cost to have an ITB manifold built? What needs to be done is put the old flange through the bandsaw and just have tubing welded on.
Old Nov 25, 2006 | 06:44 PM
RCautoworks's Avatar
Default Re: ITB Manifold cost (K2e2vin)
Well the right way would involve using a brand new flange, and right now finding someone to make an intake flange is not the easiest thing to do.
Old Nov 25, 2006 | 07:11 PM
ultra tegboi's Avatar
to chop an oem manifold, using the itb's to line up where the pipes should be welded on, a machine shop/fab shop can weld it for $60+
my buddy got his welded for $60, but it was fairly cheap cause it was in a pretty cheap place..
Old Nov 26, 2006 | 02:51 AM
K2e2vin's Avatar
I don't really want to use a new flange because the oem one is good(It's a DPFI one).
How was the quality of the $60 job?
I'm asking because I'm trying to see if it'll be cheaper to buy an OBX manifold and chop it or just have one built up.
Old Nov 26, 2006 | 05:00 AM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
i had a member on HT make me an ITB manifold from an old DPFI manifold for me, it was around $200, although for the end result and quality i got from it, i would expect to pay a bit more. the manufacturer went to lengths to blend the new tubes to the flange and the ITBs, filling in the now useless notches for the stock injectors and shaping the runners from the oval shape from the head to the round shape of the ITBs.
Old Nov 26, 2006 | 05:20 AM
K2e2vin's Avatar
I was thinking, I'd just have them weld on a straight tube, and I'll shape the inside by using a funnel made out of those cardboard paper, and filling in the open area with liquid aluminum, and shaping it with a dremel.
Old Nov 27, 2006 | 07:32 PM
Rosko's Avatar
Default Re: (K2e2vin)
I'd be worried that any epoxy or whtever would chip off and go through the motor.
Old Jan 3, 2007 | 05:15 PM
got a b16a manifold that i chopped up to run itb's, ran them using silicone couplers, but i sold all my stuff.
this half chopped, cleaned up ports manifold, $25+ shipping
Tippyman
Jul 4, 2013 07:22 PM
RCautoworks
Welding / Fabrication
24
Mar 8, 2008 10:52 AM
metal craft
32
Aug 23, 2006 12:24 PM
hxtasy
Mar 17, 2005 10:20 AM
