did a compression test and....
Old Nov 25, 2006 | 04:58 PM
EARLdaSQUIRREL's Avatar
official honda whore
Default did a compression test and....
well today i changed my oil, checked my plugs for detonation and did a compression check... my gauge only reads to 300psi and it read a little higher then that in all cylinders, i had to put a mark on the gauge to see where they were at... i know it could be off a little bit but what compression numbers should i be getting with my setup
c5 block
pct pistons
b16 head
all stock and never been decked or anything
i was thinking high 200's but not anything near 300 or higher, i realize my gauge may not be the best but i was just happy they were all consistent!!
so what does everyone else get with similar compression as me, and whats my compression supposed to be with these pistons, i have read anything from 11.8-12.7...
Old Nov 25, 2006 | 05:20 PM
Runnerdown's Avatar
Default Re: did a compression test and.... (coptzer)
yes, high 12's is where your compression is. You didnt check this before the work was done? or did you buy it like that.
around 300 psi sounds about right.
Old Nov 25, 2006 | 05:51 PM
Default Re: did a compression test and.... (Runnerdown)
ya i was pretty sure it was in the 12's but i could never find a concrete answer lol, i know c-speeds calculator is wrong because of the wrist pin placement but i could never find anyone who calculated it precisely
Old Nov 25, 2006 | 07:05 PM
EFsSuck's Avatar
not so much the wrist pin placement as much as the actual piston crown is taller...
compression is like 12.7:1... seen several setups like this in person, would never run one...
anyway two that come to mind, one pegged out a compression gauge at 300, and other kid actually bought a diesel compression tester lol.
http://www.zealautowerks.com/index.html <~compression calculator that actually works
Petah
Aug 19, 2003 11:37 PM
K20 EG
Jun 17, 2003 11:26 AM
sneakychaos
Jan 18, 2003 09:41 AM
stupidfast
Oct 20, 2002 03:50 PM
