help with SAFC NEO
Old Nov 25, 2006 | 04:25 PM
EfSedanLove's Avatar
Default help with SAFC NEO
how do i hook up this SAFC NEO in my civic? i have a 91 civic lx with a d15b2 us Mpfi converted. on the wiring diagram i believe i have to wire up
IG POWER
IG POWER
RPM
THROTTLE SIGNAL
GROUND
GROUND
VTM SIGNAL
VTEC SIGNAL OUTPUT
VTEC SIGNAL INPUT
AIRFLOW AND PRESSURE SIGNAL OUTPUT
AIRFLOW AND PRESSURE SIGNAL INPUT
ILLUMINATION POWER
I dont need vtec signal and i donno what a vtm is
Old Nov 25, 2006 | 04:57 PM
Boosted Chemist's Avatar
Default Re: help with SAFC NEO (EfSedanLove)
I think vtm is speed sensor
goto http://www.apexi.com and look up the vfac for the ef8, its pretty much the same minus vtec.
MAke sure u hook up the ground like the instruct to, the brown then the black or reverse i forget
Old Nov 25, 2006 | 05:06 PM
Default Re: help with SAFC NEO (Boosted Chemist)
i went on their its confusing
Old Nov 25, 2006 | 05:19 PM
how so?
Old Nov 25, 2006 | 05:25 PM
Right now i want to look for
IG POWER
PRESSURE SIGNAL
RPM
THROTTLE SIGNAL
GROUND
Old Nov 25, 2006 | 06:24 PM
civicjdmb16a's Avatar
This should help
Old Nov 25, 2006 | 08:46 PM
Default Re: help with SAFC NEO (civicjdmb16a)
whats
KARMA
Old Nov 26, 2006 | 11:55 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EfSedanLove &raquo;</TD></TR><TR><TD CLASS="quote">whats
KARMA</TD></TR></TABLE>
Cut the pressure wire and one is hte input (from map sensor) and one is the output (to ecu)
Old Nov 26, 2006 | 05:14 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted Chemist &raquo;</TD></TR><TR><TD CLASS="quote">Cut the pressure wire and one is hte input (from map sensor) and one is the output (to ecu)</TD></TR></TABLE>
so the wire torwards the ecu is output and the other half is input?
Old Nov 26, 2006 | 05:19 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EfSedanLove &raquo;</TD></TR><TR><TD CLASS="quote">so the wire torwards the ecu is output and the other half is input?</TD></TR></TABLE>
also my ecu has 2 map sensor pins
Old Nov 27, 2006 | 03:51 AM
Yes the afc work by modifiying your map signal
also my ecu has 2 map sensor pins</TD></TR></TABLE>
No its doesnt power, ground and signal, tap the signal wire
Old Nov 27, 2006 | 08:04 AM
My two IG Wires are hooked up to my radio which i think isnt safe, also my two Ground wires are hooked up to my radio which i also think isnt safe, my VTM wire is hooked up to my ECU but i dont think i need it, The RPM wire is hooked up to my shift light which is hoooked up to my Dizzy.
My ECU has no
IG Pin ( Unless its labeled something else ) Thats why i put them together and hooked it up to my Sterio
RPM Pin ( Unless its labeled something else ) Thats why i hooked it up to my shift light
My ECU has
2 Ground wires ( Which one do i use ) So i hooked it up to my Sterio
A16 Brown/Black
A18 Black/Red
3 MAP Sensor ( Which one do i cut? )
C11 White 1
C14 Green/White 1
C15 Yellow/Red
And
Whats KARMA!?!?!?
Old Nov 27, 2006 | 08:19 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EfSedanLove &raquo;</TD></TR><TR><TD CLASS="quote">My two IG Wires are hooked up to my radio which i think isnt safe, also my two Ground wires are hooked up to my radio which i also think isnt safe, my VTM wire is hooked up to my ECU but i dont think i need it, The RPM wire is hooked up to my shift light which is hoooked up to my Dizzy.
My ECU has no
My ECU has
A16 Brown/Black
A18 Black/Red
C11 White 1
C14 Green/White 1
C15 Yellow/Red
And
Whats KARMA!?!?!?</TD></TR></TABLE>
Look at the pinout show above, it shows u what pins to use. mapsensor signal is c11
Either ground is cool, ground is ground,
Karma is what goes around comes around
Old Nov 27, 2006 | 12:06 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted Chemist &raquo;</TD></TR><TR><TD CLASS="quote">Look at the pinout show above, it shows u what pins to use. mapsensor signal is c11
Karma is what goes around comes around </TD></TR></TABLE>
Ok so the rest of my wires are good? but i get ya.... umm VTM which is speed sensor i believe, i dont think i need that right? because usually vtec looks for speed but i dont have vtec so its useless. L0l Karma wtf! its for one of the wires i what goes around comes around is a pinout LOL!
Old Nov 27, 2006 | 04:45 PM
Ok everthing wired up now when i start it it goes then dies, start it up again, it goes then dies, then it starts whats going on?
Old Nov 30, 2006 | 07:17 AM
jz98ctr's Avatar
don't use radio wires!!!!
the ign behind the radio.....is not ign....it's acc
do yourself a favor...tag off of the fusebox or more preferably the ignition harness with the thick 12 gauge wires and tag your ignition there then run the wire to the kickpanel where the ecu is located. if you make all your connections come together into one central place...it's a little easier to diagnose and hookup.
pretty much anytime you add something you want to ground it in the kick panel....if you attach to an existing ground wire...sometimes is causes complications....it's a little extra werk
but it's worth the piece of mind to do it.
make sure you're not doing the twist-n-tape procedure(stripping wire back and wrapping the new wire around it and hopefully using electrical tape to cover the joint COMPLETELY) if you can avoid it.
if you HAVE to twist-n-tape strip back about 1/2 inch ofr the wire you're tagging into...take a pick tool or small screwdriver and "pierce" the exposed copper strands as to make a hole or loop in the strands. strip back the neo wire going to the cars wire about an inch and stick it thru the "loop" and then wrap it around the joint and tape it good. if you don't have the means to do it properly and solder it solid...this is "the next best thing" because even though there is no solder to keep it solid...as you pull on the wiring it only seems to get tighter the more you pull on it...a lot of times if you simply twist-n-tape the wire pulls out.
nehoo......high gauge high current ignition wires and separate grounds
Joecivic94
Aug 13, 2023 08:15 PM
fongck88
Jan 21, 2009 05:29 PM
digital sol
Oct 30, 2004 12:07 PM
