Swapped my old engine and turbo kit into new car have lost 80whp????
Its been along time coming, but have finally got it to the original tuner who fixed up some wiring issues. He says the car smokes abit like it may have blowen the turbo, but also claims the tune has changed some how. Rich at idle and goes abit lean when running. But is OK apparently.
He ran it up on the dyno and I have lost about 80whp, would cam timing cause a loss of this much power. Car was involved in a head on accident. So maybe it could have skipped a tooth or something.
Other possibilty is a hole in the intercooler.
It also has standard plugs in there I think at the moment needs a step cooler.
Any ideas as to what would cause such a dramatic loss in power?
ZC sohc with a ihivf22 used to make about 250whp on 13psi now makes about 170whp on 13psi
post up some dyno charts. Was this done on the same dyno? Also yes cam timing changing could have really screwed up your power. Good luck with it man
Thanks, I will see him on monday it is still a dyna pack not sure if it the same one however, being a very small shop he will not spend any amount of time on my beater will probably want it out then. So am trying to come up with ideas before I get back to him.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbozxi »</TD></TR><TR><TD CLASS="quote">Thanks, I will see him on monday it is still a dyna pack not sure if it the same one however, being a very small shop he will not spend any amount of time on my beater will probably want it out then. So am trying to come up with ideas before I get back to him.
Post up if you find anything out
</TD></TR></TABLE>Post up if you find anything out
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PINKS »</TD></TR><TR><TD CLASS="quote">Well obviously 170whp @ 13psi is wrong
My car made 293 on 13.5psi from a t3 .60/.63</TD></TR></TABLE>Thank you Captain Obvious.
Youre the one that made the post asshat
Obviously you jumped atleast 2 teeth or your losing boost
same exhaust system? Will a DOHC run being off teeth? I have yet to see a SOHC run being just one tooth off. What all is different from the car's?
Yeah it is one tooth off, same exhaust have a few leaks in it but nothing major. Correctted the cam timing and now it won't hold idle previously it idled real high now it will drop to low and die have tried adjusting the distributor as far as it will go either way with no real difference. Hopefully the tuner will be able to sort it out from here.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue »</TD></TR><TR><TD CLASS="quote">so it was off one tooth? I'm sure thats what was killing the power
</TD></TR></TABLE> Yeah hopefully thats was it.
