dome light wont turn on when you open the door
Old Nov 25, 2006 | 02:33 PM
Silent_Destruct's Avatar
Default dome light wont turn on when you open the door
my doom light doesnt work when i open the door but it does work when i put it on on. i replaced the bulbed and checked all the fuses. i am out of ideas. anybody?
Old Nov 25, 2006 | 02:39 PM
mra4886's Avatar
check your switch in the door jam . might be the problem.it might be bad and it dont know that the door is open.
Old Nov 25, 2006 | 02:49 PM
mike9571's Avatar
Default Re: (mra4886)
The connection at the switch is most likely loose or corroded. Take it off and check it out. (1screw) I was having the same problem and it turned out mine was really corroded. I cleaned it up with a little wire brush. Now its good to go.
Old Nov 26, 2006 | 03:54 PM
RedB20DA's Avatar
Default Re: (mike9571)
I had the same problem,it was the connection at the door.
Old Nov 26, 2006 | 07:02 PM
Muckman's Avatar
Moderator in Chief
Yup, loose or corroded door switch.
afnan
19
Jul 9, 2021 09:28 AM
hon0405
Dec 7, 2016 01:29 PM
ravie
Jan 26, 2008 12:38 PM
lovemyintegra1
Jul 16, 2007 11:47 PM
delguiner
Oct 5, 2005 09:19 AM
