damage crank
Old Nov 25, 2006 | 02:19 PM
vtec-gorilla's Avatar
Default damage crank
is there any way u could tell if your crankshaft is damage? just sent a vale threw a pistion, and so far everthing else looks good but cant really tell if the crank is damage
Old Nov 25, 2006 | 02:55 PM
EFsSuck's Avatar
Default Re: damage crank (vtec-gorilla)
just bring it to a reputable machine shop and have them mic it out, maybe xray/magnflux it to check for stress cracks... while its there you can have them micropolish it if its good for your next build...
Old Nov 25, 2006 | 03:07 PM
Forrest Gump 9's Avatar
Default Re: damage crank (EFsSuck)
easiest way is to run your fingernail on the journals to feel for any catch/cratch. If not, then put it back in the block with the mains and main bearings and torque it down. Try turn the crank, it should turn smoothly with little effort. If not, your crank is bent.
Old Nov 26, 2006 | 06:53 AM
Default Re: damage crank (Turbo9Nut)
i got the crank in the block already and it turns smoothly with out any effort at all and iam looking down at the crank from the cylinder walls and i dont see any damage or cracks.
Old Nov 26, 2006 | 06:59 AM
dbiker207's Avatar
pull off the three main caps in the middle of the block, leave the outer 2 on. get yourself a dial indicator and put it on the ceneter mian journel of the crank. turn the crank slowly and watch the guage. if there is more than .002 inches of movement then the crank needs to be recut. your using the block as a set of v blocks.
Old Nov 26, 2006 | 03:37 PM
d16dcoe45's Avatar
Default Re: damage crank (dbiker207)
I had 0.003" runout and I got my crank straightened at a crank shopt who had a manual press machine specifically made for straightening cranks. He got it down to around 0.0005" which is an estimation because my dial indicator only reads to 0.001"--cutting Honda cranks is iffy.
Old Nov 26, 2006 | 03:39 PM
d16dcoe45's Avatar
Default Re: damage crank (d16dcoe45)
There was a slight but definite binding if you let the crank sit in certain positions with the bearings in and the main girdle on, after he straightened it--there was no binding whatsoever. Its working great so far.
Old Nov 26, 2006 | 05:19 PM
swaytec360's Avatar
i just had an ls crank that micd out with 0.001 rollout got it in customers car and the snout is bent the pulley wobbles really sucks have to pull out of built motor
pokie
11
Jun 20, 2010 07:23 PM
teddy_dc2
Aug 8, 2007 06:37 PM
d16dcoe45
Oct 25, 2006 03:52 PM
jackstands
Mar 13, 2005 08:54 AM
skribblah
Jul 8, 2003 10:44 AM
