Mugen rear sway bar (26mm)???
Yes, I did a search, and I couldnt find anything. I would like to get the Mugen 26mm rear sway bar for my GSR...my question is, am I gonna have to upgrade to the ITR rear lower control arms, or is there someone out there who makes a bolt-on kit to use larger sway bars on the GSR?? I know that the ITRs are designed to handle a larger rear bar, but I was hoping that I wouldnt have to change the rear LCAs (I really dont wanna have to buy new shocks again). Does anyone know the deal with this, or give me any help?
The 26mm bar costs $370US from King.
Wouldn't the 26mm be alright with your mounting kit or even the Beaks kit? Isn't the reason that the 26mm is listed for the ITR is b/c of its reinforcement of the subframe?
Thats what I was wondering...how much does this kit go for??
depends on how you drive and what rear spring rates you run , just get the kit or make your own
thats an EXPENSIVE fix if you do get tearout , i'd rather have peace of mind and not worry about it
what are the chances of a tear-out if you use a type R sway bar in a rs, without the reinforcement kit?
"USDM Type-R 22mm rear swaybar (~$57) or the JDM Type-R 23mm rear swaybar (~$90-$110). "
Where can get theses bars at those prices???websites??
You can get the 22mm one from www.acuraautomotiveparts.net
That is where I found to be cheapest. If you are going to mount this bar, go to BSQ's site and read up on all the parts and steps.
Edit: Made it a link for those lazy people.
[Modified by GSRrR, 11:44 PM 12/10/2002]
I would either recommend the USDM Type-R 22mm rear swaybar (~$57) or the JDM Type-R 23mm rear swaybar (~$90-$110). BTW, the 22mm increases the torsional rate by 720% over the stock rear sway bar. The 23mm increases the torsional rate by 880% over the stock rear sway bar.
BudMan
Jan 23, 2003 11:11 AM
