Those with Skunk2 manifolds...
Old May 9, 2002 | 07:54 AM
VTC_CiViC's Avatar
Default Those with Skunk2 manifolds...
I've got a question regarding VTEC engagement with the Skunk manifold. Since the new manifold eliminates the dual runner setup with the stock GS-R mani, what do you do for VTEC? Do you leave it engaing at 4500rpm? I'd be running this with no VTEC controller, so I'd have to leave it at the stock X-over, will that run ok or do you notice a drastic loss of torque with the big lobes taking over so soon without the aid of long runners?
Or on the flip side, are the small lobes of the P72 enough to support power up to 5.5-5.6k like the other B motors?
Old May 9, 2002 | 08:28 AM
FAST94GSR's Avatar
New User
Default Re: Those with Skunk2 manifolds... (VTC_CiViC)
it really depends on your setup, ie high compression, lower compression, turbo, what cams you are runningblah blah. Typically you set the xover higher. I will tell you this you will get a nice fat midrange pick up with the manifold, it is engineered right. Gotta love skunk2
If your putting it on basically a stock engine you will not experience the gains until way up.
Old May 9, 2002 | 12:41 PM
TeamTooQuick's Avatar
Default Re: Those with Skunk2 manifolds... (FAST94GSR)
get a type R ECU.....
Old May 9, 2002 | 01:12 PM
Mr. Softee's Avatar
Default Re: Those with Skunk2 manifolds... (TeamTooQuick)
do not get a type r ecu. a 5700 engagement with stock cams is WAY too high. Just leave vtec as is with gsr cams.
-sam
pokemon
Jan 25, 2009 07:09 PM
GranadaTeg
Feb 20, 2006 03:23 PM
AK94GSR
Jun 11, 2003 02:24 PM
LOwrestling2001
Apr 8, 2002 02:39 AM
C4wrx
Mar 5, 2002 04:49 AM
