hondata s200. Can not pull cel code
Old Nov 25, 2006 | 07:04 AM
tecnic1's Avatar
Default hondata s200. Can not pull cel code
I recently bought a car with hondata s200 already installed.
It is now throwing a check engine light and is in safe mode.
however, when I jumper the connecter to put it into diagnostic mode, It doesn't go into diagnostic mode.
Is there another way to pull the code?
Also resetting the ecu does not clear the code or reset safe mode, or if it does clear it, it comes back instently....
Thanks
Old Nov 25, 2006 | 07:36 AM
b19coupe's Avatar
Default Re: hondata s200. Can not pull cel code (tecnic1)
You can use Hondalogger to pull the code if you have a laptop.
Zaraki
Mar 31, 2008 08:26 PM
Austin
Jul 16, 2006 05:16 PM
Black DC2
Sep 2, 2005 08:20 PM
94lsboost
Mar 26, 2005 10:30 PM
tz-devil77
Jan 21, 2003 12:37 PM
