S2000 SPEEDOMETER CLUSTER 2004-2006 WORK ON?
Plugs are different, so you have to swap plugs after pinning them out. Personally I don't think it's a good idea. It won't display the last 1000rpms of your rev range.
Thanks for answer me! i don't think about it.
Another Idea: Need a not electronical Speedometer...
how to change my speedometer... have a idea?
just curious why do you want to modify our highly accurate OEM tach? Just tap the tach signal wire, set the tach for 4 cylinder, and run a power, ground, and dash lighting wire.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LAS2K »</TD></TR><TR><TD CLASS="quote">just curious why do you want to modify our highly accurate OEM tach? Just tap the tach signal wire, set the tach for 4 cylinder, and run a power, ground, and dash lighting wire. </TD></TR></TABLE>
I think he's asking about an analog (non-digital) speedometer...not a tach. But still, don't all years have digital speedometers....and digital everything?
yes! yes! yes! I need analog Speedometer .. non digital..
my speedometer cluster broaken, need to change. where buy and how much?
Go to http://www.car-part.com.
Select a search for any AP1 year (2000-2003)
Select "Honda S2000" from the make/model list
Select "Gauge/Cluster/Instrument" from the par list.
Select the second option on the model year dialog box and set the first year to 2000 and the second year to 2003
You will then get a list of available parts from around the country and prices.
I always call with a list of questions before I buy from a listed vendor to ensure that we are talking about "apples and apples."
Good luck
Good luck
Ktuned2007
Jul 8, 2007 10:13 PM
jdmturbosol
Oct 18, 2006 02:24 PM
Whats the purpose for swapping the cluster by chance?
