What is spring surge & Why should i make sure my Valve Train is adeqauate
Old Nov 24, 2006 | 10:54 PM
Combustion Contraption's Avatar
Default What is spring surge & Why should i make sure my Valve Train is adeqauate
http://www.we-todd-did-racing....t.wmv
right click save as, turn your sound down.
Old Nov 25, 2006 | 03:11 AM
Chillinit's Avatar
Default Re: What is spring surge & Why should i make sure my Valve Train is adeqauate (Combustion Contraptio
Dam! Thanks for the vid. Its not often we get to see engine components at work in real time like this. BTW..what spring was that?
Old Nov 25, 2006 | 03:31 AM
alterdcreations's Avatar
looks like a diesel
Old Nov 25, 2006 | 10:51 AM
NJIN BUILDR's Avatar
http://www.spintron.com/
CV Products has on available for rent.I have seen footage with the spring "floating".Neither touching the seat or the retainer.This is a critical tool for valve spring development.I know Comp Cams and Isky have them.
Old Nov 25, 2006 | 03:31 PM
GSRCRXsi's Avatar
now is that an example of an adequate spring setup? or no? any idea what rpms that motor was at?
Old Nov 25, 2006 | 08:58 PM
yugadnoh's Avatar
never seen a diesel run a T@D shaft mounted rocker arm and it was spining way
to many rpm's to be a diesel
Old Nov 25, 2006 | 09:08 PM
all_motor_mike's Avatar
whats a T@D shaft mounted rocker arm?
Old Nov 25, 2006 | 10:17 PM
yugadnoh's Avatar
T@D is the manufacture,a rocker arm is the blue thing you see going up and down,
and its mounted on a shaft instead of a stud.
Old Nov 26, 2006 | 12:32 AM
im a diesel mechanic................ Detroit to be exact. i just didn't know if the T@D thing was a typo. and just to throw it in there the engines i work on use shaft mounted rocker arms on a OHC design engine. and i agree with u 100% about the engine spinning way to fast to be a diesel.
Old Nov 26, 2006 | 06:58 AM
GSRCRXsi's Avatar
how do you know how fast the engine is spinning?
Old Nov 26, 2006 | 07:19 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alterdcreations &raquo;</TD></TR><TR><TD CLASS="quote">looks like a diesel</TD></TR></TABLE>
it was just a tought
it looks like its on the verge of floating
(but i am no expert)
Old Nov 26, 2006 | 04:19 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRCRXsi &raquo;</TD></TR><TR><TD CLASS="quote">how do you know how fast the engine is spinning?</TD></TR></TABLE>
the characteristics of the valve motion.
Old Nov 26, 2006 | 05:53 PM
GSRCRXsi's Avatar
well how fast is it spinning then? and what characteristics do you use to translate that into an actual number or range of possible RPMs?
Old Nov 26, 2006 | 10:42 PM
What do you want, an exact number? Im saying, for the valve to be "bouncing" like that, you got to be spinning a little faster than a deisel normally would.
Old Nov 27, 2006 | 04:38 AM
GSRCRXsi's Avatar
Default Re: (Combustion Contraption)
no not at all. i know pin pointing a number would be near impossible unless you know the speed of the camera. i was just wondering what you were looking at to estimate speed. just trying to learn
Old Nov 27, 2006 | 09:44 AM
yugadnoh's Avatar
Default Re: (GSRCRXsi)
listen to the video.sounds to me like its spining about 8,000.
Old Nov 27, 2006 | 10:13 AM
Rocket's Avatar
Default Re: (yugadnoh)
Surge is much like a tidal surge. **** just keeps going when it shouldn't.
There are a couple design elements that can lessing this "surge". One is have an inner and outer spring rub each other. Another is to have the spring assymetrically wound in various configurations that produces varying spring rate along the length of the springs, another simple one is to anchor both ends of the spring. But what do I know, I am just a lackey.
Good topic. Constipation Contraption.
Cosworth Products
Old Nov 27, 2006 | 10:18 AM
Default Re: (Don Lackey)
maybe a nascar v8 two valve per cylinder.
Old Nov 27, 2006 | 10:22 AM
d16dcoe45's Avatar
Default Re: (alterdcreations)
You can see the top of the valvestem slightly bouncing away from the rocker!! That is insane!! The spring almost looks like its made of some sort of gelatinous material.....
Old Nov 27, 2006 | 10:25 AM
d16dcoe45's Avatar
Default Re: (d16dcoe45)
I don't want to jack the thread but it is sort of related. How come there isn't a SINGLE beehive spring/retainer designs for any Honda motor available? They are getting big in domestics. I can't see any drawbacks to it. You could use a steel retainer that is just as light or lighter than a "conventional" titanium retainer--and have steel's durability, using beehives.
Old Nov 27, 2006 | 07:46 PM
ShaunRR's Avatar
HT White Ops
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16dcoe45 &raquo;</TD></TR><TR><TD CLASS="quote">I don't want to jack the thread but it is sort of related. How come there isn't a SINGLE beehive spring/retainer designs for any Honda motor available? They are getting big in domestics. I can't see any drawbacks to it. You could use a steel retainer that is just as light or lighter than a "conventional" titanium retainer--and have steel's durability, using beehives.</TD></TR></TABLE>
I remember there being a discussion about this design in the old RM forum. I have that forum now, but I don't have time to do a search right now. If you want, you can take a look for yourself. The link to it is in the "home page" part of my profile.
Old Nov 27, 2006 | 07:56 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Don Lackey &raquo;</TD></TR><TR><TD CLASS="quote"> Constipation Contraption.
i hate you.
Old Nov 27, 2006 | 07:57 PM
Professor15's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Combustion Contraption &raquo;</TD></TR><TR><TD CLASS="quote">
i hate you.</TD></TR></TABLE>lol hate is a very strong word
Old Nov 27, 2006 | 07:59 PM
Hate is too strong an emotion to waste on someone you dont even like.
kenpoed
Mar 4, 2014 03:35 PM
Matty.
Apr 12, 2006 07:40 AM
importlegions
Jul 15, 2004 08:53 PM
Screamer
Dec 17, 2003 04:41 PM
