what size socket for axle nut?
Old May 9, 2002 | 07:31 AM
keithv's Avatar
Default what size socket for axle nut?
i am not sure if the axle nuts take a 32mm socket ot get off. i know its around 32mm. can anyone help?
thanks.
Old May 9, 2002 | 07:34 AM
marty's Avatar
Default Re: what size socket for axle nut? (breaka_1_9)
32mm.
Old May 9, 2002 | 07:36 AM
keithv's Avatar
Default Re: what size socket for axle nut? (MugenEF7)
thanks!!!
Old May 9, 2002 | 07:48 AM
integRated109's Avatar
i had to make 3 trips to sears last week for that thing....my ACURA shop book has a typo and says 22, so i sent my friend for a 22 mm not even thinking about it...be prepared to buy a 1/2 inch breaker bar if you dont have one because i dont think a socket that big comes in 3/8.
Old May 9, 2002 | 08:49 AM
keithv's Avatar
Default Re: what size socket for axle nut? (integRated109)
thanks...i have my trusty 1/2" craftsman breaker bar, so i should be good to go!
Old May 9, 2002 | 08:50 AM
Mugen Dom's Avatar
1 1/4 works to with the trusty impact gun breaker bar may work but they are on tiiiight...
Old May 9, 2002 | 08:52 AM
keithv's Avatar
Default Re: what size socket for axle nut? (jdmB18hatch)
the axle nuts were loose recently, so i hope they come off easily. if not, i'll just have to tow the car to my friends house which is where i changed axles the last time.
thanks for all the replies guys.
[Modified by breaka_1_9, 12:53 PM 5/9/2002]
Old May 9, 2002 | 09:10 AM
crxjunky's Avatar
you may already know this , but make sure you pry up that little notched area that is folded over, if ya dont it could munge up the threads
[Modified by crxjunky, 6:10 PM 5/9/2002]
Old May 9, 2002 | 07:13 PM
marty's Avatar
Default Re: what size socket for axle nut? (crxjunky)
they're called cotter pins.
Old May 9, 2002 | 07:23 PM
StorminMatt's Avatar
A cotter pin is an actual pin that goes through a hole. But there is no hole or pin. Just a notched area on the axle into which you pound the outer wall of the nut itself.
Old May 9, 2002 | 07:25 PM
marty's Avatar
Default Re: what size socket for axle nut? (StorminMatt)
why would you pound your axle? remove one 14mm and one 17mm, pull the spindle out and the outer axle falls out.. no pounding.
Old May 9, 2002 | 07:31 PM
chhuong's Avatar
He meant by pound, to lock the axle nut, to the axle!!
Old May 9, 2002 | 07:44 PM
marty's Avatar
Default Re: what size socket for axle nut? (chhuong)
oh duh
75aces
Sep 23, 2015 03:28 PM
89s1
Sep 6, 2007 08:17 PM
ricerodder91EX
33
Apr 14, 2007 12:24 PM
Mr.Meowsome
38
Nov 25, 2006 04:33 PM
gsrcivic619
10
Jan 5, 2004 04:07 PM
