Removing stock valve cover breather - Answering my own question
Old Nov 24, 2006 | 07:52 PM
Sprockets's Avatar
Default Removing stock valve cover breather - Answering my own question
A few days ago I created this post...
https://honda-tech.com/zerothread?id=1815568
...asking about the removal of the stock valve cover breather. It doesn't have to be cut off. I was able to remove this fitting on a spare valve cover with some vise grips. I had planned to drill and tap for a 1/4" NPT fitting, but there's aluminum that goes about 3cm back from the opening. The diameter seems perfect for 1/8" NPT without having to drill. What surprised me is the length of the stock tube. Pics are below.
Old Nov 24, 2006 | 08:07 PM
Tchleung's Avatar
Wow, thats alot longer then I would have thought. I did this same thing on my ITR intake manifold. I ripped out 2 vacuum ports out with pliers without too much hassle, and taped one for 1/8" npt and another for 1/4" npt. perfect :D
Old Nov 24, 2006 | 10:12 PM
I.C.C.'s Avatar
ive been planning to do this for a while... good to know i dont need to cut it now... I just wanna plug mine and weld two -10AN fittings on the front of the cover
Old Nov 24, 2006 | 11:42 PM
abnaasefmb's Avatar
Default Re: (I.C.C.)
good deal. i would think you would want to go bigger than 1/8 though
Old Nov 25, 2006 | 04:21 AM
JoePSI's Avatar
Default Re: (abnaasefmb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abnaasefmb &raquo;</TD></TR><TR><TD CLASS="quote">good deal. i would think you would want to go bigger than 1/8 though</TD></TR></TABLE>
What are you using this for?
This isnt a good place for a catch can setup, but i think you already knew that.
Modified by JoePSI at 6:10 AM 11/25/2006
Old Nov 25, 2006 | 06:47 AM
2point2's Avatar
From what I remember, a 1/8 npt is smaller than the OEM Honda PCV tube. I welded the hole shut and had a 1/2npt bung welded on to the SIDE of the valve cover.
If anyone needs bungs to do this, lmk.
Old Nov 25, 2006 | 11:39 AM
Sprockets's Avatar
I know 1/8" NPT is small. I have some extra -6an hose ends that I'm not going to use, so I decided to do this. I'm having 2 -10an bungs welded on the front of the valve cover, otherwise I wouldn't have bothered doing this. By the way, the inside diameter of the tube that was removed is slightly more than 6mm. The inside diameter of the -6an hose ends I have are 7mm. Why would you guys weld this hole shut?
Old Nov 25, 2006 | 03:21 PM
abnaasefmb's Avatar
Default Re: (Sprockets)
sounds good, should work well!
Old Nov 25, 2006 | 03:47 PM
JoePSI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sprockets &raquo;</TD></TR><TR><TD CLASS="quote">Why would you guys weld this hole shut? </TD></TR></TABLE>
Its the stock PCV system if you hook up a catch can its not needed anymore, all it will do is dirty up your engine bay.
Charlie Moua
Welding / Fabrication
16
Nov 12, 2010 01:38 PM
NathanMorris
Aug 7, 2006 07:28 AM
d16dcoe45
14
Aug 6, 2006 03:12 PM
