ex front sway bar & si rear sway bar...
Old Nov 24, 2006 | 07:14 PM
stuie08's Avatar
Default ex front sway bar & si rear sway bar...
alright, i am looking to put a rear sway bar on my 00 civic. I want to kepp the front sway(ex front) and then get any si rear sway bar. i was wondering if anyone has this combo and how they like it. and would these two be a good combo. also would a beaks rear subframe enforcement be enough for the si rear(13mm)?
Old Nov 24, 2006 | 07:21 PM
Eran's Avatar
HT White Ops
with an Si swaybar, you don't need a beaks kit.
Old Nov 24, 2006 | 07:45 PM
turnsignalandy's Avatar
Default Re: (Eran)
however do your research! Im on the same path as you, althoughh I already have the swaybar, but im missing some parts. If i get it on before you do ill let you know how it is.
Old Nov 25, 2006 | 01:34 PM
stuie08's Avatar
alright, i cant find a place that sells them though. h-t market, anywhere? where'd you get yours? and what is your setup going to be?
Old Nov 25, 2006 | 02:30 PM
BlueIntegraBoy's Avatar
Default Re: (stuie08)
You'll find them in the H-T classifieds once in a while. If not, Honda probably has them for not too much money. You'll need all the hardware too from Honda if you don't get it all when you buy a used one.
Ruben19
Suspension & Brakes
May 7, 2010 12:56 PM
Rouin
Honda Civic (2006 - 2015)
Mar 11, 2007 12:51 PM
turnsignalandy
May 28, 2006 09:14 PM
p1driftfiend
14
Feb 23, 2004 12:18 PM
