tranny fluid
on a 4th gen how do i change the transmission fluid?
someone told me id only drain a third if i just uncapped it and let it drain out cuz its still stuck in the tranny when the car is off?
can someone clear this up
When changing the tranny fluid, only 1/3 of the fluid actually drains out. So to do a better job of replacing the dirty fluid, you should change it 3 times, with a short drive between each change. Use only Honda ATF-Z1, with no additives.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KillerElfboy »</TD></TR><TR><TD CLASS="quote">how many bottles should i use each time i change it?
like to do the whole thing am i gonna need a 3 bottles (1 bottle for each 1/3 change)</TD></TR></TABLE>
you use up around 2-2.5 quart each time.
Blacknight117
30
Jul 3, 2011 07:25 AM
