95 accord LX problem..im stumped
Old Nov 24, 2006 | 05:24 PM
loup05's Avatar
Default 95 accord LX problem..im stumped
ok i have a CD5 and its been acting up. It started one day when i was on the freeway on ramp i was doing like 40-45 and all of a sudden it felt like i had lost a cylinder. It felt like i wasnt getting spark or fuel, as if i was going up a very steap hill. the problem happens once in a while and varies in speeds it does it when ever it wants. So i decided to get oem spark plus, wires, and a oem fuel filter. also i had oil in the spark plugs so i decided to change the rocker seals. everything was good after i drove it but the next day (today) it started to act up again. can anyone help me out? btw there is no engine light on
Old Nov 24, 2006 | 06:17 PM
loup05's Avatar
Default Re: 95 accord LX problem..im stumped (loup05)
nothin? no real techs here?
Old Nov 25, 2006 | 05:17 AM
jdmappealcd7's Avatar
you started with the right thing checking your spark plug wires, if still no fix after that my 95 accord starting doing the same thing and it was my egr ports- i know that most obd1 accords 92-95 except 95 v6 which has obd2 will not throw a code or check engine light for egr ports-it may for egr valve( insufficent lift). cleaning these ports out are not a big hassel and can be done with basic hand tools. Find a haynes book and it will tell you how to.--- by the way you still may have a temp. code in the ecu and the check engine light NOT on. If you have any buddies that work at a shop or dealership they can hook the obd2 scanner w/ the obd1 hookup and find any temp. codes. this may help. goodluck!
Old Nov 25, 2006 | 05:43 AM
jaghouse's Avatar
Default Re: 95 accord LX problem..im stumped (jdmappealcd7)
Sorry to highjack but I currently have a similar problem. My 95 LX seems to miss/hesitate at idle when the engine is up to temp. and during half throttle or more acceleration. Check engine light has not come on. I have given it a complete tune up and a valve lash and still the problem persists. The misses/hesitation are more prominent when the engine is warm. Also it does not seem to be a problem at higher RPMs. Mostly a problem at less than 2000 RPM. Could the EGR or EGR ports be the problem?
I would like to clean the EGR ports but I dont think my old Haynes manual states how to. Do you take off the EGR and then start drilling the ports? Do you need to take the head off?
Modified by jaghouse at 7:08 AM 11/25/2006
Old Nov 25, 2006 | 06:06 AM
jaghouse's Avatar
Default Re: 95 accord LX problem..im stumped (jaghouse)
OK, did some Google-ing and came up with this very nice tutorial:
http://home.comcast.net/~em-engineering/T2T013.pdf
Looks like on 94+ Accords no drilling is necessary.
One last question, Would clogged EGR ports cause a rough idle?
Old Nov 25, 2006 | 05:22 PM
loup05's Avatar
yea i had reserched that also. I guess i will try to do that tomorrow at work also i checked the codes and it gave me a code 43 faulty H02S.
hey jdmappealcd7 what do u mean i might have a temp code?
loup05's Avatar
btw i did not use a scanner to get the code 43
Old Nov 26, 2006 | 05:01 PM
loup05's Avatar
ok back to this. i dont know what bolts to remove so it can be easier for me to acces the egr ports
Old Nov 27, 2006 | 06:08 AM
jaghouse's Avatar
After taking off the fuel rail/injectors there are 5 bolts that secure the cover. Romove those and you will have access to the ports. I did this... cleaned the ports and the track inside the cover and it did NOT solve the problem. I also checked out the EGR valve and selenoid for connectivity and function with some other tests and everything checked ok. Damn it ..... time for a new Accord.
Old Nov 27, 2006 | 10:50 AM
75thRanger's Avatar
I actually cleaned the egr ports this past weekend. I used this website as a tutorial, it only took about an hour and 45 mins. Gosh you should have seen the egr ports and the track. I might as well have had an egr plate on the engine.
Old Nov 27, 2006 | 05:06 PM
loup05's Avatar
Default Re: 95 accord LX problem..im stumped (75thRanger)
i meant b4 removing the fuel rail i dont kno what bolts to take off
smh0101
Jan 3, 2014 02:29 PM
erl_loggins
Aug 18, 2013 01:13 PM
715_guy
May 13, 2008 08:27 PM
94_civicEx
Jan 23, 2006 07:44 AM
