erratic idle and vtec questions
Old Nov 24, 2006 | 02:55 PM
iggut's Avatar
Default erratic idle and vtec questions
Hey! ok I gor 2 questions
lets start with the problemtatic one:
I am not sure if this only happens when its cold outside but this started occuring few days ago when it got lot colder outside. When I start my Civic Si VTEC Coupe 94 it revs at 2000 ( i'm guessing to heat the engine up), and if i leave it running for 5 min and then go, there will be no problems. BUT when i do not leave it running for 5 min or so and just start and leave on the spot and then at a stop i press my clutch the idle will keep jumping from around 800-1500 (this stopps hapenning after 5 min of driving).
and question number 2:
I'm new to vtech and somone told me it should kick in around 4400 RPM. I am looking to buy a chip for my ECU, but the ones on ebay for my ecu P28 are all set to 5700 RPM kick in. I am not sure if it is better for the vtec to kick in at 4400 or at 5700 RPM any suggestions please.
Old Nov 24, 2006 | 03:12 PM
bsixteen's Avatar
#2: honda put the vtec engagement point there for a reason. i say don't mess w/ it.
as for 1. no idea
Old Nov 24, 2006 | 03:21 PM
iggut's Avatar
Default Re: (bsixteen)
Yeh i though so too, but then again why the hell would all those chips on ebay be set at 5700.....
Old Nov 25, 2006 | 12:16 PM
iggut's Avatar
Default Re: (iggut)
bump
Old Nov 25, 2006 | 02:13 PM
Datedda's Avatar
I had that same problem w/ my hatch, check your Throttle cable all the way up into the firewall and make sure that there is no worn pieces, if there are any wires showing you need to replace it...and if not then take it to a shop while it is idling crazy and they can manually adjust it.
Old Nov 25, 2006 | 02:36 PM
pdiggitydogg's Avatar
ebay is full of crap... Dony buy into 99% of the stuff on there.
vtec should be at 5500 <u>+</u>200rpm...leave it there.
The car is supposed to idle high at startup when its cold.
The fluctuating is probably a dirty IACV. Clean it - located back of the intake manifold (2 collant lines, 1 e- connector.) Search for how to do this
Old Nov 25, 2006 | 02:50 PM
cranny's Avatar
24.224.233.247
Default Re: (pdiggitydogg)
here sticky this ****. like the most common asked question on any honda forum.
http://www.cb7tuner.com/vbb/showthread.php?t=53161
Old Nov 26, 2006 | 04:02 PM
iggut's Avatar
Default Re: (iggut)
bump
Old Nov 26, 2006 | 04:08 PM
iggut's Avatar
Default Re: erratic idle and vtec questions (iggut)
thanks, i'm gonna try to clean it next weekend when i get some free time.
Old Nov 26, 2006 | 04:27 PM
streettuned's Avatar
It will idle real high if you have a could air intake, I live in wi and my civic does that,
what engine do you have? The vtec doesn't engage at 4400, is it a gsr? if it is, the gsr has butterfly valves that open at 4400, maybe thats the cross over you are hearing.
Old Nov 26, 2006 | 08:32 PM
whit3's Avatar
Default Re: erratic idle and vtec questions (streettuned)
IAT clean it with carb cleaner and buy a new screan. if still occurs adjust. using screw on throttle body big on on front
Old Nov 29, 2006 | 04:30 AM
cranny's Avatar
24.224.233.247
Default Re: erratic idle and vtec questions (whit3)
if it hasnt already been tampered with , DO NOT adjust the idle screw on an FI car.
Bj Le Det
Jan 6, 2017 12:06 AM
Metal Head
10
Aug 2, 2006 12:58 PM
mr_vtec
May 6, 2005 01:33 AM
Mr_CRX
Sep 29, 2004 12:01 PM
