upper driverside mount??
Old Nov 24, 2006 | 01:34 PM
hondachris1994's Avatar
Default upper driverside mount??
What yr and car do I order the upper driverside mount..my car eg with b16a2, and my mount isnt broken but the rubber is startin to fall apart, would I b better off gettin inserts oe a new mount, what do u guys think?
Old Nov 25, 2006 | 02:39 AM
bump
Old Nov 25, 2006 | 02:47 AM
teamvirus's Avatar
My car breaks a lot!
Default Re: (hondachris1994)
its really up to you...if you have the money buy aftermarket "hasport" if not...the junk yard works great
Old Nov 25, 2006 | 03:09 AM
Default Re: (teamvirus)
what year car do i order it from? is it a civic mount or a teg mount?
Old Nov 25, 2006 | 03:17 AM
teamvirus's Avatar
teg mount
Old Nov 25, 2006 | 03:19 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teamvirus &raquo;</TD></TR><TR><TD CLASS="quote">teg mount </TD></TR></TABLE>what yr(s)?
Old Nov 25, 2006 | 03:48 AM
teamvirus's Avatar
94-01
Old Nov 25, 2006 | 05:24 AM
nsxmatt's Avatar
Is it a real B16a2 or a second gen jdm b16a? The jdm motor uses a 2 bolt angle mount which is the same as a 92-93 Civic upper mount. If it's a a2 then it depends on the bracket they used. It could be the same mount or the 3 bolt 94-up teg or 94-95 Civic si/ex upper mount. Take a picture and we'll tell you.
Old Nov 25, 2006 | 05:27 AM
eg_boi's Avatar
Default Re: upper driverside mount?? (hondachris1994)
just get hasport mounts it'll save u the time and money later on down the road. it'll cost u some $$ but hasport mounts are worth it
Old Nov 25, 2006 | 05:39 AM
Default Re: (nsxmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt &raquo;</TD></TR><TR><TD CLASS="quote">Is it a real B16a2 or a second gen jdm b16a? The jdm motor uses a 2 bolt angle mount which is the same as a 92-93 Civic upper mount. If it's a a2 then it depends on the bracket they used. It could be the same mount or the 3 bolt 94-up teg or 94-95 Civic si/ex upper mount. Take a picture and we'll tell you.</TD></TR></TABLE>here's a pic, camera phone pic so not so great http://i46.photobucket.com/alb...d.jpg
Old Nov 25, 2006 | 05:46 AM
nsxmatt's Avatar
Good enough, it's the 94-01 teg or 94-95 Civic Ex/Si mount. If the rubber is torn, don't put a insert in it just replace it.
Old Nov 25, 2006 | 05:52 AM
thanx for all the help HT
vtecthiss
Sep 7, 2008 09:51 PM
CRX_Banned
Jan 3, 2008 08:35 AM
brookliner7
Apr 5, 2005 06:44 PM
