Function/Form Type I Coilovers
Ok, I'm not too keen on suspension and have done some searching and have only found a few things on the Function/Form coilovers but seem to have found good reviews and they seem like a great suspension set. Well I'm seriously considering buying these http://www.f2autolife.com/stor...id=39
I just have a few questions:
1) Does this fit the SH?
2) I would like to get into autocross next summer and wonder if these would be exceptional and are they decent enough for daily driving?
3) What is a good spring rate for daily driving/weekend tracking?
Thanks for the help.
they should
good for daily driving....autox, if you want to go a little further you will want a more robust setup. (gc/koni)
thats up to you, everyones driving habit is different. but my suggestion? 750lb/650lb
they should
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by petern101 »</TD></TR><TR><TD CLASS="quote">
Wow thats extremely aggressive. I suggest closer to 400-500lbs (I beleive konis can only handle about 450lbs with stock valving.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cb7-R »</TD></TR><TR><TD CLASS="quote">
Wow thats extremely aggressive. I suggest closer to 400-500lbs (I beleive konis can only handle about 450lbs with stock valving.)</TD></TR></TABLE>
you are right. but he said "tracking" and well i can't judge by how much he wants.
the question was failed from the start and the answer coincided with it
right now i'm at 450lbs and feel its a little on the softer side nowadays.
ry_guy
Oct 23, 2006 06:20 AM
