Disc Rotor dimensions
What are the critical dimensions/requirements for a front disc rotor swap? Apart from the PCD and total diameter. I hear that the thickness of the rotor is critical as well. Is this true?
Yes, the thickness is important because you don't want to resurface the rotor past this limit. I don't have the numbers off hand, but can find out when I get home later tonight.
<U>Front</U>
Standard = 21mm (0.827")
Max Refinishing Limit = 19mm (0.748")
<U>Rear</U>
Standard = 9mm (0.350")
Max Refinishing Limit = 8mm (0.320")
<U>Rear</U>
The above was for a Civic.
Type-R
<u>Front</u>
Standard = 22.9-23.1mm (0.900"-0.910")
Max Refinishing Limit = 21.0mm (0.830")
<u>Rear</u>
Standard = 8.9-9.1mm (0.350"-0.360")
Max Refinishing Limit = 8.0mm (0.310")
Type-R
<u>Front</u>
<u>Rear</u>
BrakeExpert
16
Jul 25, 2009 10:45 AM
forevernewbie
Aug 7, 2007 10:55 AM
