m24x vs toda c
Old Nov 24, 2006 | 06:22 AM
saintspall's Avatar
Default m24x vs toda c
just tuned my dart 2.1 engine today with m24x.Dropped 4whp at the high end and lost bout 5-9whp t all other range,isit becos i don have enough compression.
Old Nov 24, 2006 | 07:55 AM
b19coupe's Avatar
Default Re: m24x vs toda c (saintspall)
Could be the cams need to be degreed...?
Old Nov 24, 2006 | 08:39 AM
mRvYbEs's Avatar
Can you post a graph/dyno sheet please
Old Nov 24, 2006 | 08:42 AM
98vtec's Avatar
moderator emeritus
info?
Old Nov 24, 2006 | 04:06 PM
saintspall's Avatar
Default Re: m24x vs toda c (b19coupe)
tried to degree the cam but it does nothing.will try to post the graph but its a big dip for the m24x all the way till 7k.My current comp is about 12ish,85x95 dart block.
Old Nov 24, 2006 | 04:08 PM
DonF's Avatar
Did you put them to the recomended centerlines?
Old Nov 24, 2006 | 04:11 PM
Runnerdown's Avatar
I would'nt consider your compression any factor in the cams performance of one vs another, an 85 x 95 moves a lot of air. What are the rest of the specs on you setup?
Old Nov 24, 2006 | 05:16 PM
UncleD's Avatar
Default Re: m24x vs toda c (Runnerdown)
Your motor is large enough, thats not the problem
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote">Did you put them to the recomended centerlines? </TD></TR></TABLE>
Old Nov 24, 2006 | 07:22 PM
saintspall's Avatar
Default Re: m24x vs toda c (clean rice)
I'm using a 4-1 extractor with 3" exhaust straight through,victor x mani and 68mmtb,so what could be the problem?Cam was set according to cam spec provided by rokect.Tried to ad exhaust and retart intake but it does'nt seems to do anygood.Is it because of the head?
Old Nov 24, 2006 | 07:24 PM
Combustion Contraption's Avatar
what do you mean you "tried" to set to the specs according to rocket? Either you did or you didnt... there is no "try". (hehe)
Old Nov 24, 2006 | 07:59 PM
ShaunRR's Avatar
HT White Ops
Community Builder
FYI, setting the cam gears at 0,0 does not qualify as degreeing the cams, if that is what you are thinking.
Old Nov 24, 2006 | 08:30 PM
Adi Radoncic's Avatar
On Fire!
Default Re: m24x vs toda c (rochesterricer)
I would degree the cams and get a bigger throttle body..
Old Nov 24, 2006 | 08:56 PM
b19coupe's Avatar
Default Re: (Combustion Contraption)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Combustion Contraption &raquo;</TD></TR><TR><TD CLASS="quote">there is no "try". </TD></TR></TABLE>
Wax on Wax off!
Old Nov 25, 2006 | 08:47 AM
saintspall's Avatar
Cam was set to spec provided by rocket,didnt gain any and lost power throughout the range,tried to degree the cams at the dyno and it didn't get any better.get the pict?
Old Nov 25, 2006 | 10:17 AM
ShaunRR's Avatar
HT White Ops
Community Builder
Default Re: (saintspall)
List the specs you degreed them to.
Old Nov 25, 2006 | 03:04 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saintspall &raquo;</TD></TR><TR><TD CLASS="quote">Cam was set to spec provided by rocket,didnt gain any and lost power throughout the range,tried to degree the cams at the dyno and it didn't get any better.get the pict?</TD></TR></TABLE>
You dont degree cams on a dyno, you do it on an engine stand. Get the picT?
Old Nov 25, 2006 | 11:47 PM
vteczone's Avatar
i think he meant he adjusted the adjustable camgears on the dyno..
but Combustion Contraption is right u need to degree the cams according to the spec given (on the engine stand).. for example the intake valve must start to open (usually 1mm lift) at certain recommended crankshaft degree and this must match with the cam spec given.
Old Nov 26, 2006 | 07:35 AM
saintspall's Avatar
Default Re: (vteczone)
Well ya i adjusted the cam on an dyno and degree the cam with the engine off the car and was set according to given spec.
Old Nov 26, 2006 | 09:34 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rochesterricer &raquo;</TD></TR><TR><TD CLASS="quote">List the specs you degreed them to.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">Could be the cams need to be degreed...?</TD></TR></TABLE>
WHAT WERE THE SPECS YOU DEGREED THEM TO?
b19coupe
56
Apr 22, 2013 10:24 AM
tomlinson619
17
May 24, 2006 04:37 AM
Edward
Nov 3, 2005 02:59 PM
dohcter g
91
Jun 16, 2005 04:19 PM
FastAllmotorLsVtec
Jun 7, 2005 05:12 AM
