Toda B's or Buddy Club spec 3
Old Nov 24, 2006 | 05:48 AM
HONDASPANCHO's Avatar
Default Toda B's or Buddy Club spec 3
im in a huge dilema. I have these 2 sets of cams and dont know wich ones to put in. My goal is to try to reach 210whp or more. wich cam you guys think will help me more....ive been searching for hours now and i want to deside so i can go finish putting my motor toghether and get it running so any info would be gratly appreciated guys thanx...
i currently have a B16 head with mild P&P.
dual valve springs and titanium retainers,
supreteck flat faced valves with black nitride coating and 3 angle valve job.
and custom itb's.
the bottom end is a B18c1 with Jdm oversiced ITR pistons, shootpeened rods, fidanza 7 pound flywheel and i got the whole rotating assebly balanced.
its finished of with a custom header and tuned on crome.
so if you had these 2 sets of cams wich would you drop in thanks again.
Old Nov 24, 2006 | 10:04 AM
civicstar's Avatar
Default Re: Toda B's or Buddy Club spec 3 (HONDASPANCHO)
THE BC3 are alot smaller, i orginally ran the toda b in a motor like that but make sure those valve springs u have can acutally handle them, if they cant, they collapse and u end up bending alot of valves. but u will make more power with the todas but the bc3 are safer,
Old Nov 24, 2006 | 11:20 AM
THANKS....they springs will hold up...when i purchased them they told me they would hold up to 9500..not that im going to be reving that high just wanted to have springs that would be strong enough.
Old Nov 24, 2006 | 12:13 PM
any more info
Old Nov 24, 2006 | 12:35 PM
civicstar's Avatar
Default Re: (HONDASPANCHO)
Buddy Club Spec III Plus
Spec III plus were designed to accommodate compression ratios from 10.0:1 to 13+. Specifications:
Intake 304 duration 11.59 mm lift
Exhaust 294 duration, 10.71mm lift.
Toda Spec B
iNTAKE: 12 mm 255 @ 1mm
Exhaust:12.5 mm 255 @ 1mm
THE BC3 has the longer duration, meaning the valves are open longer, that has to do with the power band from mid end
The Todas have the higher lift, meaning thats gonna be a bigger top end and peak hp. there are alot more on the cams, thats jsut a summary, id use the Bs for Drag but the BC3 for daily driven
Old Nov 24, 2006 | 12:42 PM
b19coupe's Avatar
Toda B's, hands down.
Old Nov 24, 2006 | 03:52 PM
good info..im leaning more towards the b's myself. thanx guys hopefully 1 day i reach my 210whp goal.
Old Nov 24, 2006 | 04:01 PM
flesh199's Avatar
bc3 are like stage 0.5 camshafts loll go with toda spec b for sure the nonvtec lobe are huge...My last camshaft was toda spec b...
Old Nov 29, 2006 | 01:39 PM
well i think i might trow the b's in well have to wait till this weekend and see.
Old Nov 29, 2006 | 04:38 PM
TwoRedEGgs's Avatar
We have ran both and the Toda's are a little harder to tune and the idle is a little harder to get perfect but they always seemed to make more power! Your Vtec crossover will have to be higher then the BC3's also !!
Old Dec 13, 2006 | 05:08 PM
99BULLET's Avatar
Default Re: (TwoRedEGgs)
i make 214whp with my old set up
b20 vec full buit
toda b cams...runs strong and no problem for 2 years dayle drive
Old Dec 13, 2006 | 05:54 PM
SkoundrelUSA's Avatar
cute little bastard
Default Re: Toda B's or Buddy Club spec 3 (b19coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">Toda B's, hands down.</TD></TR></TABLE>
x1000
baysic r
Jun 29, 2009 11:49 PM
SuperImport
Apr 22, 2006 11:12 PM
Tech6023
Sep 12, 2005 02:38 PM
AllmotorJunkie
Mar 6, 2003 01:17 PM
vtec69
Oct 27, 2002 06:07 PM
