Crank Pulley
Can i put H23 Crank pulley to my H22 JDM ?
And do you recoment light weight crank pulley? as CFR or Unorthodox?
is it common that, the crank pulley breaks? the alternator pulley falled off
btw, im from iceland, dont write good english
Hi
I dont know if the H23 pulley will fit, but I recomend using the stock one.
The stock pulley is designed to dampen vibration harmonics and is important for engine/bearing life.
Some say it is bullshit, but Honda recomend using the stock. They have developed the pulley and there is big amoun of $$ involved.
The stock one is so expensive. But I have a h23 engine, but the problem is that, the engine is 300 miles away from me, so I cant compere the h23 pulley to the H22 pulley, so I asked here.
