engine stuttering
Old Nov 23, 2006 | 05:56 PM
lx130's Avatar
Default engine stuttering
arite.....got a zc sohc motor swap into my 90 crx....not sure what tranny or how old...got it from a friend already swapped...
so ill be stopped at a light...and this happens probably every 3 lights or so...and so then...as i step on the clutch let go a little and gas it...it starts to go a little then when i reach around 2,000 rpm it starts to stutter and jump a little kinda like sputtering and sounds sorta like its about to die...friend to a qucik look at my car drove it a little...and said it may be the clutch thats causing it its old or worn or something...but yea....jw some feedback on this... thanks
Old Nov 24, 2006 | 11:04 PM
lx130's Avatar
Default Re: engine stuttering (lx130)
any one?!?!?!?!??
Old Nov 25, 2006 | 07:34 PM
ryanplayjoint's Avatar
It sounds like the clutch or maybe bad clutch adjustment, Try adjusting the clutch cable and get back to us.
Old Nov 25, 2006 | 07:53 PM
cbp_crx's Avatar
Default Re: engine stuttering (ryanplayjoint)
we already answered this question on crx community. Its highly doubtful its your clutch, if it was going out, it would be slipping and the engine would rev. As most everyone told you over there, check you plugs, wires, cap, rotor etc.
Old Nov 25, 2006 | 07:55 PM
cbp_crx's Avatar
Default Re: engine stuttering (cbp_crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ryanplayjoint &raquo;</TD></TR><TR><TD CLASS="quote">It sounds like the clutch or maybe bad clutch adjustment, Try adjusting the clutch cable and get back to us.</TD></TR></TABLE> What would any of that have to do, with the engine stuttering or sounding like it was going to die?
Old Nov 25, 2006 | 09:12 PM
diego1985's Avatar
how's the idleing? sounds like something in the fuel delivery system vacuum hoses? you need to provide more info diagnosing that its kinda hard
Old Nov 25, 2006 | 09:14 PM
cbp_crx's Avatar
Default Re: (diego1985)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by diego1985 &raquo;</TD></TR><TR><TD CLASS="quote">how's the idleing? sounds like something in the fuel delivery system vacuum hoses? you need to provide more info diagnosing that its kinda hard</TD></TR></TABLE> thats true also. I had this problem, and it turned out to be a vaccum leak
Slotz_HB
Sep 29, 2009 08:34 PM
stevenDAtegra
Transmission & Drivetrain
Jun 25, 2009 04:12 PM
Nicaraguense13
Mar 13, 2007 04:36 AM
steveo2000em1
11
Aug 9, 2006 03:42 AM
EF_yo_89
Dec 24, 2003 03:28 PM
