integra
Old Nov 23, 2006 | 04:39 PM
zero2hero's Avatar
Default integra
when it rains my trunk is filled with water.need help asap. can anyone help
Old Nov 23, 2006 | 04:42 PM
rutherfordhigh's Avatar
Default Re: integra (zero2hero)
same thing happens to my integra, so let me know what it is
Old Nov 23, 2006 | 04:57 PM
98GSRrdr's Avatar
Used to happen to me .. take out your tail lights and make sure that ... lol i forget what its called.. the Rubber gasket ? Is nice and tight the whole way around on the inside ... I fixed this on mine and the water hasnt returned .. but now my tail lights fog alittle every once in awhile.
So id check out ur tail lights Also i think ive heard ppl say about the antenna area leaking
Old Nov 23, 2006 | 05:02 PM
Fat Chick Magnet's Avatar
same happen to mine. i drilled a tiny hole in my trunk under the spare tire and everything drained out overnight. but you got to replace some sorta seal when you take your tail lights out.
Old Nov 23, 2006 | 05:11 PM
PrinceAli132's Avatar
Also check your sunroof drain tubes, if you have a sunroof. Sometimes the drain tubes come loose or get clogged. To access them remove the rear panels and you should see tubes.
Ali
Old Nov 23, 2006 | 05:13 PM
Dogginator's Avatar
Daisy... Daisy...
Pull the trunk interior and strategically line the trunk with paper towels to trace the source of the leak. The most common culprit is the taillight gasket. I have seen wheel wells leak as well.
Old Nov 24, 2006 | 06:20 PM
zero2hero's Avatar
Default Re: integra (98GSRrdr)
thanks for the help
Old Nov 24, 2006 | 06:21 PM
zero2hero's Avatar
and my back seats are wet too. why is that im confused
vega_ROCKS
Dec 18, 2008 12:19 AM
SLH356
Jul 3, 2006 08:00 PM
TXGirl
Jul 7, 2003 02:48 PM
