Door panel question
Old Nov 23, 2006 | 04:12 PM
Homesickelian's Avatar
Default Door panel question
My door panel on my drivers side is nasty and has cigarette burns on it. It's in dire need of replacement and I think I can get it cheap at a junk yard.
I just want to make sure so I don't ruin my part or the one at the junk yard.
Pretty mutch all you do is remove all of the screws that hold in the latch panel and the control panel, then pry it off correct?
Is there any good way to pry it off without mangling it?
Old Nov 24, 2006 | 04:08 PM
PnX-R's Avatar
Default Re: Door panel question (Homesickelian)
Hmm.. 94 Accord huh... Well here's rookie tip, when removing the door handle, don't pull it towards you after removing the two screws behind the cap.. I learned my lesson my first time around. Remove the two screws and slide the door handle towards the hinge. It will then just fall out and you'll just have to disconnect the release lever. As to what else needs to come out, there should be at least two more screws by armrest.. Not too sure, but I'll know if I have it in front of me..
Nuts
Honda S2000
Aug 7, 2008 06:32 PM
bbhockey19
Jan 24, 2007 09:29 AM
todd.ludwig
May 1, 2006 02:27 AM
Moonbus
Jan 3, 2004 08:41 PM
teg95
May 22, 2002 01:16 PM
