WIRING HELP!
Old Nov 23, 2006 | 01:34 PM
code47mastermind's Avatar
Default WIRING HELP!
Modified by code47mastermind at 2:17 PM 7/15/2007
Old Nov 23, 2006 | 01:44 PM
by takin off my cluster, i figured out where the one near the cluster is.. anyone know where the first one plugs into?
Old Nov 23, 2006 | 01:55 PM
djdm's Avatar
Default Re: WIRING HELP! (code47mastermind)
I had the same problem is ur srs light on cause if it is then its to the driver side airbag located on the steering wheel hope thats wat it is good luck
Old Nov 23, 2006 | 08:22 PM
projectegr's Avatar
Default Re: WIRING HELP! (djdm)
SRS Plugs, All receiving ends will be yellow as well. Check steering, above fuse-box, gauge cluster, under radio console, and behind glove box. Hope this helps
9.3.S.I.L.U.D.E.
18
Aug 20, 2009 01:50 AM
Eg_mE
Dec 29, 2008 06:42 AM
CTRwannaB
Sep 26, 2007 09:59 AM
1baddc5
Apr 15, 2007 06:15 PM
Manolo
Dec 28, 2005 05:20 PM
