JDM GSR Head build Q's?
Here's the deal. I own a 94 JDM B18c1. I want to make more power, but keep the bottom end stock for financial purposes. Here are the parts I was thinking of going with:
Skunk2 Pro series IM
ITR throttle body
Rage Try-Y header
ARP head studs
Omni Power high compression valves
Omni Power dual valve springs and titanium retainers
Cams?
Injectors?
I'm going to use high compression valves and a thinner headgasket to raise the compression a little bit to make more use out of the cams. But my problem lies here. I am not sure with what cams would go good with my setup, or what size injectors to use. If anybody has any imput or information that would be helpful I would appreciate it. Oh yeah, this will be tuned on chrome.
ITR throttle body
Rage Try-Y header
ARP head studs
Cams?
Injectors?
im planning on having a simmilar setup as you on my jdm gsr, im thinking of going with the jun3 copies or something, even tho id LVOE a set of m22x's but theyre expensiveeeeeee and im brokeeeee
If you have not already purchased the Intake Mainfold why not go with a AEBS or Blox unit to save a few more dollars. AEBS also offers a very affordable throttle body.
I am a big fan of having a valvejob done while any head is off you may want to see what your local options are and have that done. Insted of buying Omni valves you could also mill your head some to increse compression and save a few more dollars. The increse from the omni valves is minimal.
I see you left out cam gears in your list and they are quite important if you plan on getting the most out of your build, and are a must if you decide to mill the head.
I already have the intake manifold. I bought it right before I did my swap. I couldn't stand the snail manifold. I forgot to put cam gears on the list, but I didn't forget about them. I don't want to mill the head. I was lookin into valve jobs, and that will probobly be done as well. Any thoughts on good cams?
well , the $$$ you spend on valves and head studs , that you don't realy need could get you some ITR or B16 pistons that would get more out of a good set of cams. I have a set of Blox HSL's and Pro 1's if you need cams
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaboyB18C1 »</TD></TR><TR><TD CLASS="quote">well , the $$$ you spend on valves and head studs , that you don't realy need could get you some ITR or B16 pistons that would get more out of a good set of cams. I have a set of Blox HSL's and Pro 1's if you need cams</TD></TR></TABLE>
I really dont feel like tearing into the bottom end. It only has 40k miles on it, and runs perfect.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NA_B18C1 »</TD></TR><TR><TD CLASS="quote">i heard those guys in minn..ain't even all that good at tuning and performance wise. </TD></TR></TABLE>
well good for you.
well good for you.
stiness101
13
Apr 23, 2007 10:03 AM
Hatchorama
May 18, 2006 06:48 AM
rcurry14
Oct 6, 2004 10:42 PM
