Wich speedometer sensor work with CUSCO LSD on Y1 ?
Hello,
I try to put my CUSCO LSD (RS 1 way) in my Y1 and the ring gear on it, isn't compatible with my speedometer pinion .... The ring gear is approx 3mm largeur than the original one. Somebody have a solution ?
Thanks,
Thanks,
Ok .... Same lenght .... But my probleme is, in fact, the diameter of the ring gear on lsd. And it's was directly machined on the LSD body.
Maybe the cusco was normaly provide with a specific VSS/pinion ? **** ......
Or the JDM one is different ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gilou bilou »</TD></TR><TR><TD CLASS="quote">Or the JDM one is different ?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nerologic »</TD></TR><TR><TD CLASS="quote">all 5spd B/D series VSS are the same length...</TD></TR></TABLE>
JDM UKDM USDM CDM
all same...
maybe u put it on wrong??
snap a pic inside the hole...
is the tranny running/working rigth now?
JDM UKDM USDM CDM
all same...
My Cusco LSD for my Type-R trans came with a speedometer pinion, you should call cusco and see if they made one for the Y1.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicB18C5 »</TD></TR><TR><TD CLASS="quote">My Cusco LSD for my Type-R trans came with a speedometer pinion, you should call cusco and see if they made one for the Y1.</TD></TR></TABLE>
the ring gear for the diff is actually almost the same size on a y1 and R, so im sure thats his problem...
In fact, after comparaison with an OEM gear, the cusco is largeur (approx 96mm) and the OEM size is approx 93mm .....
Now, my only solution is to contact cusco to know if it's possible to buy the pininon only ....
Thanks for your help !
Modified by gilou bilou at 9:30 AM 11/25/2006
drift2004
Dec 17, 2007 10:46 AM
NirVTEC
16
Dec 13, 2003 08:27 PM
