help me please 97 ls with 99 swap
Old Nov 23, 2006 | 02:09 AM
thaibigboi's Avatar
New User
Default help me please 97 ls with 99 swap
well her-es the story.... i got an alarm instaled in my tegra and they put my warning light where u cant see it soo i moved it right by my cluster soo i took out my cluster cuz it was in the way when i was done putting the light in the spot i wanted it i go 2 start my car and none of gagues work and i cant select any gears.... dose any 1 have any idea wutz wrong? oh check all my fuse nothings blown....
Old Nov 23, 2006 | 05:06 AM
Swiftstar's Avatar
Default Re: help me please 97 ls with 99 swap (thaibigboi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thaibigboi &raquo;</TD></TR><TR><TD CLASS="quote">well her-es the story.... i got an alarm instaled in my tegra and they put my warning light where u cant see it soo i moved it right by my cluster soo i took out my cluster cuz it was in the way when i was done putting the light in the spot i wanted it i go 2 start my car and none of gagues work and i cant select any gears.... dose any 1 have any idea wutz wrong? oh check all my fuse nothings blown....</TD></TR></TABLE>
if this is about a wiring problem your having, why is your tread topic about an Engine Swap??
Old Nov 23, 2006 | 11:56 AM
f2rider's Avatar
How about this.
Title: Cluster issues after alarm warning light installation
Message: Well here is the story, I got an alarm installed in my Integra. During the installation they mounted my warning light were it wasn't even visible. After seeing this I decided to move it to an area that was more visible (right by my cluster). I ended up removing my cluster in order to do my own installation and ever since I put it back it hasn't worked.
I don't have any warning lights or gear indicators now and my guages don't even work. I have already checked the fuses. Does anyone have any idea's?
Reply: You will get better help if you choose the correct title and write a little bit more clear. Anyway, make sure you didn't mess up the green film on the back of the cluster and check to make sure you plugged everything back in. I would also check the fuses again because this really does sound like a fuse issue. Good luck.
bresk8r87
Oct 17, 2007 07:47 AM
EH-3
17
Mar 15, 2006 03:23 PM
dungsta
May 15, 2005 01:57 PM
nxstrikerxn
Jul 9, 2004 08:00 PM
