did compression test (with oil and without oil)
1995 GSR w/ 90k miles
1st compression test without oil being added to the cylinders.
cyl 1- 175
cyl 2- 160
cyl 3- 160
cyl 4- 165
2nd compression test with a cap of oil added to the cylinders.
cyl 1- 190
cyl 2- 185
cyl 3- 195
cyl 4- 190
any good?
question: after the oil being added to the cylinder and starting the car up is it supose to smoke out the exhaust and smell like oil is burning?
cyl 1- 175
cyl 2- 160
cyl 3- 160
cyl 4- 165
cyl 1- 190
cyl 2- 185
cyl 3- 195
cyl 4- 190
any good?
tha'ts normal number for a B18C. the number sometime is not too important but how close they're from one another. Compression shouldn't be more than +-20psi different from one cyl to the other. It look like your rings may need to be replace soon. Ohh yeah, do a leak down test that will deffinately tell you more about how healthy your motor is than a Compression TEST.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda1982 »</TD></TR><TR><TD CLASS="quote">tha'ts normal number for a B18C. the number sometime is not too important but how close they're from one another. Compression shouldn't be more than +-20psi different from one cyl to the other. It look like your rings may need to be replace soon. Ohh yeah, do a leak down test that will deffinately tell you more about how healthy your motor is than a Compression TEST.</TD></TR></TABLE>
ok, but which numbers do i look at? the 1st compression test i did or the 2nd one?
and how long will my 2nd compression test numbers last?
ehh im getting paranoid i dont feel like dropping $2000 changing my rings, all seals, head gasket, and new rod bearings....might as well change all that since im riping my motor apart.
Guest
Posts: n/a
You would pay attention to the 1st ones. Adding oil is just showing approximately how much is getting blown past your rings. in the 170s still isnt too bad and your numbers are all pretty close together.
I wouldnt worry about rebuilding just yet. Wait til they are less than 150, or maybe its 140 to rebuild. Unless you are going for performance.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4MOTION »</TD></TR><TR><TD CLASS="quote">maybe bad head gasket problem? *someone correct me, if iam wrong*</TD></TR></TABLE>
dont think so. im still going to do a leak down test see what my main problem is until i decide if im going to take action or not.
hope someone steals my car so i dont end up droping $2gz rebuilding my engine.
nekoabandoned
Jul 24, 2006 03:39 PM
