bad camber.
Old Nov 22, 2006 | 04:42 PM
jikespingleton's Avatar
Default bad camber.
my 94 gsr is on tociko shocks and tein S springs and my camber is really off. is there a way i can fix it with out gettin coilovers with camber plates. wat about the omni power adjustable comtrol arms?
Old Nov 22, 2006 | 04:45 PM
PrinceAli132's Avatar
Default Re: bad camber. (jikespingleton)
For the fronts you can get an adjustable front upper control arm. Skunk2 and Omni are two companies that make them.
For the rear's you can do the washer trick or get and adjustable piece. There are many companies that offer this product.
Ali
waddy41's Avatar
u can get camber kits on its own..not neccessarily coilovers with camber plates..
for the rear u can shimmm it
also...there are nitto neogen is a tire that's special for cars with excessive camber..helps reduce camber wear a little
Old Nov 22, 2006 | 04:59 PM
iH8RICERZ's Avatar
Default Re: (waddy41)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by waddy41 &raquo;</TD></TR><TR><TD CLASS="quote">
also...there are nitto neogen is a tire that's special for cars with excessive camber..helps reduce camber wear a little</TD></TR></TABLE>
hmm...didn't know that. I'll keep that in mind next time I buy a set of tires.
Old Nov 22, 2006 | 05:01 PM
qfast817's Avatar
Default Re: (iH8RICERZ)
its cheaper to buy a camber kit in the long run
Old Nov 22, 2006 | 06:00 PM
waddy41's Avatar
Default Re: (qfast817)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by qfast817 &raquo;</TD></TR><TR><TD CLASS="quote">its cheaper to buy a camber kit in the long run</TD></TR></TABLE>
neogens costs more..and they dont perform as well cuz the inner is made of harder rubber
Noah Santana
11
Jan 18, 2017 06:09 AM
genetsang
Sep 16, 2004 11:39 AM
CrX-To-Tha-Max
Mar 4, 2004 07:17 PM
austrian type-R
Jul 8, 2003 10:46 AM
Chip398193
Jul 29, 2001 11:38 AM
