Post your t3to4b setup #s
Old Nov 22, 2006 | 03:37 PM
turbo boost's Avatar
Default Post your t3to4b setup #s
hey curioues to see what my lsvtec will make for #s with a t3to4b
post trim S,V,H ...ar
manifold..dp size...
thanks
Old Nov 22, 2006 | 05:22 PM
Default Re: Post your t3to4b setup #s (snowbunny)
come on people???
Old Nov 22, 2006 | 08:49 PM
StylishDOHC's Avatar
Old Nov 22, 2006 | 10:14 PM
KeyserSoze's Avatar
What's a to4b??? Is that a new kind of turbo?
On the real tho, I had a straight t04b on my gsr-t before i changed everything up and got a holset. Back then the setup was (don't laugh!!!):
GSR
Head:
Mild pnp
crower vavletrain
crane stg II na cams
skunk2 im
Block:
Stock
Turbo/Management (if you could call it that):
AFC
dsm 450's
missing link
b&m fpr
walbro 255
garrett t04b 50 a/r comp, 48 a/r turbine
full 3" exhaust (including 3" cat)
Made 240whp and some shitty wtq # (i don't remember and my subconscious is prolly blocking it out to protect my ego) @ 7psi
I know its not a hybrid, but I felt sorry for you and this is the only bone I had to throw.
Edit: The comp wheel was a v-trim wheel.
Modified by KeyserSoze at 1:48 AM 11/23/2006
Old Nov 22, 2006 | 11:43 PM
F20Cteg's Avatar
Default Re: Post your t3to4b setup #s (KeyserSoze)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snowbunny &raquo;</TD></TR><TR><TD CLASS="quote">hey curioues to see what my lsvtec will make for #s with a t3to4b
thanks </TD></TR></TABLE>
T04B has a wide spectrum there buddy. Tiny little S trim all the way to the 66 trim 62-1.
For LS/VTEC, I wouldn't go with anything smaller than a V trim.
Now if you are after a low to mid torque range then a super 60 might be ideal, but I don't think you are after mid range.
92sihatch59
Jan 10, 2023 09:18 AM
95exdsmkilla
Mar 22, 2010 10:49 AM
turbohatch eg6
Jul 2, 2009 06:40 PM
94CRVtec
Apr 17, 2003 05:59 AM
