What ngk spark plugs are better iridium or platinum?
Old Nov 22, 2006 | 12:46 PM
Midori Green's Avatar
Default What ngk spark plugs are better? Iridium or platinum?
Im looking to buy some spark plugs for my 96 civic and I want to know which of these spark plugs are higher quality. Iridium or platinum?
Old Nov 22, 2006 | 01:46 PM
Perfectionist's Avatar
Default Re: What ngk spark plugs are better? Iridium or platinum? (EKfreak)
Use the plug your owner's manual or the label under the hood specifies. The main advantage to using platinum or iridium is longer service life. The performance gain is negligeable in your application.
Old Nov 22, 2006 | 01:49 PM
ninja 6's Avatar
Default Re: What ngk spark plugs are better? Iridium or platinum? (Perfectionist)
I believe the platinum plugs last longer. As far as performance goes, Iridium.
Old Nov 22, 2006 | 02:06 PM
-Gambit-'s Avatar
Default Re: What ngk spark plugs are better? Iridium or platinum? (ThatGuy4life)
You wont notice a difference buying expensive plugs with a stock motor or even a motor with bolt ons. Just get regular ngk's
Modified by -Gambit- at 7:20 PM 11/22/2006
Old Nov 22, 2006 | 04:01 PM
old man neri's Avatar
Copper maybe?
Old Nov 22, 2006 | 04:26 PM
Midori so sickkkkk's Avatar
Default Re: (old man neri)
i use iridiums....but i think a plug is a plug.....
Old Nov 22, 2006 | 05:19 PM
ridin98civic's Avatar
Default Re: (1sickdelsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1sickdelsol &raquo;</TD></TR><TR><TD CLASS="quote">i use iridiums....but i think a plug is a plug..... </TD></TR></TABLE>
unless its bosch, then its just garbage
iridium
Old Nov 22, 2006 | 05:20 PM
CodyC142's Avatar
Default Re: (ridin98civic)
autolight FTW
Old Nov 22, 2006 | 05:54 PM
FRWYKNG's Avatar
Default Re: (CodyC142)
don't waste your money on those, buy some oem ngk spark plugs.
Old Nov 22, 2006 | 06:50 PM
djmnc's Avatar
Have you heard about the "Silver" Spark plug??? Silver is the best electrical and thermal conductor of any metal, which makes it the ultimate material for a spark plug's center electrode. This is only base on my personal choice, ONLY if you're into racing... and if you're not into racing competitions..consider those pervious posts you read as follows:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 450oNSLiCkS &raquo;</TD></TR><TR><TD CLASS="quote">don't waste your money on those, buy some oem ngk spark plugs. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1sickdelsol &raquo;</TD></TR><TR><TD CLASS="quote">...but i think a plug is a plug..... </TD></TR></TABLE>.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Perfectionist &raquo;</TD></TR><TR><TD CLASS="quote">Use the plug your owner's manual or the label under the hood specifies. The main advantage to using platinum or iridium is longer service life. The performance gain is negligeable in your application.</TD></TR></TABLE>
Old Nov 22, 2006 | 07:26 PM
Eran's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ridin98civic &raquo;</TD></TR><TR><TD CLASS="quote">
iridium </TD></TR></TABLE>
What a completely retarded standpoint. If everything but Bosch was garbage, then why would Honda use NGK V-Power? Why would Honda recommend using NGK plugs?
Bosch spark plugs are designed for european vehicles, don't let the guy's at Autozone fool you.
Old Nov 22, 2006 | 07:31 PM
bart2546's Avatar
I just replaced mine, could have bought iridiums for something around 10 bucks a plug, but I went with regular stock NGK that were 1.98 per plug, they work just fine, no change in performance good or bad, regular NGK FTW
Old Nov 22, 2006 | 07:33 PM
Eran's Avatar
HT White Ops
Default Re: What ngk spark plugs are better? Iridium or platinum? (bart2546)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bart2546 &raquo;</TD></TR><TR><TD CLASS="quote">I just replaced mine, could have bought iridiums for something around 10 bucks a plug, but I went with regular stock NGK that were 1.98 per plug, they work just fine, no change in performance good or bad, regular NGK FTW</TD></TR></TABLE>
That's V-Power for you I pay 5.99 + tax for all four, and they're the exact same plugs you'd buy at honda for over $3 per plug
Old Nov 22, 2006 | 07:56 PM
Default Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">
Bosch spark plugs are designed for european vehicles, don't let the guy's at Autozone fool you. </TD></TR></TABLE>
thank you! i agree! i'm a girl and i hate when people on the forums try to make me look stupid!! thanks for the backup!
Old Nov 22, 2006 | 08:08 PM
Default Re: (Eran)
well eran not to be a dick, but i was saying that bosch plugs were garbage and ngk iridiums were good. in fact i use ngk. so before you try and flame me re-read something before dislexia sets in and you think it says something else.
and i wasnt trying to make you look stupid either 1sickdelsol. i was simply stating that you were mostly correct in your statment of "a plug is a plug" unless that plug is anything bosch. read FTW
Old Nov 22, 2006 | 08:11 PM
Eran's Avatar
HT White Ops
"unless its bosch, then its just garbage"
That makes you sound like you like only Bosch.
"Unless it's Bosch, those are garbage."
Old Nov 22, 2006 | 08:12 PM
Default Re: (Eran)
no i said, a plug is a plug, unless it is bosch then it is just garbage
Old Nov 22, 2006 | 08:13 PM
Eran's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ridin98civic &raquo;</TD></TR><TR><TD CLASS="quote">read FTW</TD></TR></TABLE>
Learning how to type FTW.
actually im confusing myself, damn sleeping through english class
Old Nov 22, 2006 | 08:14 PM
Eran's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ridin98civic &raquo;</TD></TR><TR><TD CLASS="quote">no i said, a plug is a plug, unless it is bosch then it is just garbage</TD></TR></TABLE>
When you make a sentence fragment like:
It's the same as saying:
"It's just garbage unless it's Bosch."
My mother's an english teacher.
Old Nov 22, 2006 | 08:15 PM
Default Re: (Eran)
ok so somebody put that lil hammer symbol thing so i can E-beat myself in the head
Old Nov 22, 2006 | 08:16 PM
Eran's Avatar
HT White Ops
: + hammer + : =
Knock yourself out.
Old Nov 22, 2006 | 08:17 PM
Default Re: (Eran)
pain inflicted, time for drunken stupor
Old Nov 22, 2006 | 08:34 PM
EK k kay's Avatar
He was continuing the other guy's post. Read it as one sentence.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">i use iridiums....but i think a plug is a plug..... </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">unless its bosch, then its just garbage</TD></TR></TABLE>
Old Nov 22, 2006 | 08:45 PM
inline4's Avatar
Default Re: (EK k kay)
i don't get it
so bosch is like the garbage unless it is something else then it's not like garbage but garbage is everything else so bosch is garbage because everything else is garbage but what about another mans garbage is another mans treasure could bosch be a treasure or can other things be treasure unless its garbage but it could be but maybe not ya knows.
