***Tranny Popping out of 5th and leaking tranny fluid***
I have a oo EM1 stock b16 tranny and it been leaking fluid and popping out of fifth every time i put like a quart or so in like a few days it pops out again and i keep putting more fluid in it but when i put fluid in it doesn't pop out,
WHere could it be leaking from its not from the axle it looks wet all the time from where the shift linkage goes into the tranny
thanx guys
thanx guys
ya when ur low on tranny fluid it likes to pop out of 5th gear...my tranny did that b4 until i changed my tranny fluid...there is a seal where ur shift linkage goes into the tranny, it might be leaking from there...replace that seal and u should be fine if there isnt more leaks elsewhere
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb16 »</TD></TR><TR><TD CLASS="quote">ya when ur low on tranny fluid it likes to pop out of 5th gear...my tranny did that b4 until i changed my tranny fluid...there is a seal where ur shift linkage goes into the tranny, it might be leaking from there...replace that seal and u should be fine if there isnt more leaks elsewhere</TD></TR></TABLE>
VTEC-DA
Sep 6, 2003 11:43 AM
