Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Something wrong with my shifter/gears?
Old Nov 22, 2006 | 11:24 AM
yed's Avatar
yed
Default Something wrong with my shifter/gears?
My shifter moved easy through gears until last night after I had dinner and I was leaving and then my shifter felt odd. It feels like I have to force it just slightly into the gears or that there's some resistance, as if my clutch wasn't pressed in fully. Is this something I should be concerned about?
Old Nov 22, 2006 | 11:26 AM
Type X's Avatar
Default Re: Something wrong with my shifter/gears? (yed)
happens occasionally USUALLY when your parked and you have to go in reverse or first.
I row through the gears before i move to "loosen it up"
and its fine after that.
Old Nov 22, 2006 | 11:28 AM
yed's Avatar
yed
It's happening through all my gears though, not just reverse or first.
Old Nov 22, 2006 | 11:29 AM
Type X's Avatar
Default Re: (yed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yed &raquo;</TD></TR><TR><TD CLASS="quote">It's happening through all my gears though, not just reverse or first.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type X &raquo;</TD></TR><TR><TD CLASS="quote">happens occasionally USUALLY when your parked and you have to go in reverse or first.
and its fine after that. </TD></TR></TABLE>
Old Nov 22, 2006 | 11:30 AM
yed's Avatar
yed
Didn't mean to say you were wrong or anything. Just elaborating on my problem Your response was much appreciated anyway
Old Nov 22, 2006 | 12:21 PM
AbsoluteGG's Avatar
i have an lx coupe mt and sometimes mine does that but when im trying to get into reverse. i wait for the rpms to drop to 1k or lower.
Old Nov 22, 2006 | 12:22 PM
yed's Avatar
yed
Anybody else know what might be wrong? I was thinking about driving it over to the dealer. I've never had a brand new car before so how does warranty go? Can I just drive it over there and they'll see if there is a problem for free?
Old Nov 22, 2006 | 12:25 PM
WILD_WILL's Avatar
Default Re: (yed)
Yes you wont be charged for them to look at it alot of people have had problems with the gearbox,2cd/3rd gear issues just take it in if it continues.
Old Nov 22, 2006 | 12:32 PM
Hellzcivic's Avatar
You can take it in, but they will tell you nothing is wrong. I have the same problem when the car has been parked for a while or it is cold. Once the car warms up, it improves back to what feels "normal".
Like Mike (Type-X), I run the shifter through the gears a couple times before I take off.
Are stating that it is still difficult even after the car has warmed up? Remember, the gear box uses like 80 weight oil. When that stuff gets cold, it's like molasses.
Old Nov 22, 2006 | 01:28 PM
yed's Avatar
yed
Everything was fine and I parked the car for an hour or two only. I always warm up my car, plus it's like 80 degrees here. I was still driving around a little last night and drove some today, still feels odd.
And yeah, I am a little afraid of going to the dealer and them saying nothing is wrong or not caring much about it. Especially since I didn't buy it from them(purchased out of state).
Modified by yed at 3:46 PM 11/22/2006
Old Nov 22, 2006 | 07:12 PM
spammy123's Avatar
my 2nd gear was completly thrown out of wack and honda tore my tranny out had a specialist come in and rebuild 2nd with all its internals at no cost. warranty covers it.
Old Nov 22, 2006 | 07:58 PM
Rahxephon's Avatar
i've read your other post....and you've said this is your 1st manual car!! i'm not saying you don't know how to drive but i guess you've get used to it.
Old Nov 22, 2006 | 08:08 PM
newdanger's Avatar
Default Re: (spammy123)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spammy123 &raquo;</TD></TR><TR><TD CLASS="quote">my 2nd gear was completly thrown out of wack and honda tore my tranny out had a specialist come in and rebuild 2nd with all its internals at no cost. warranty covers it.</TD></TR></TABLE>
did you look under the hood (cable bushings) and in the shifter box itself to see if anything was out of the ordinary???
Old Nov 22, 2006 | 08:21 PM
yed's Avatar
yed
Default Re: Something wrong with my shifter/gears? (Rahxephon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rahxephon &raquo;</TD></TR><TR><TD CLASS="quote">i've read your other post....and you've said this is your 1st manual car!! i'm not saying you don't know how to drive but i guess you've get used to it.</TD></TR></TABLE>
That's why I'm asking though. I wasn't sure if it was normal in a manual car that it might change for some reason that could be explained or if something was wrong with my shifter/gears. It feels different now than it did the whole week I've been driving it before this. I thought at first maybe I was just tired or something, but there is definitely a different feel to it now.
As for looking under the hood, I wouldn't know what to look for.
Old Nov 23, 2006 | 12:18 PM
90dteg's Avatar
Default Re: Something wrong with my shifter/gears? (Hellzcivic)
Honda's don't use 80w for tranny oil. It is closer to a 10-30. Go buy a bottle of 80w and Honda Manual Trans fluid and tell me it is like 80w. It is far from it.
Old Nov 23, 2006 | 06:29 PM
Fa1's Avatar
Fa1
If you're grinding reverse, make sure your car is completely stopped, and shift into first, then reverse. It helps out alot sometimes.
CountryHonda
12
May 11, 2008 08:55 PM
tei344
11
Jul 18, 2007 10:36 PM
RedRocketDX
16
Sep 23, 2006 10:28 PM
TurboBumblBee
11
Feb 22, 2004 10:22 PM
Kato7997
24
Sep 12, 2003 09:19 PM
