FS:Built B-Series Motor and Turbo Kit (Chicago)
Less than 200 miles on the block and turbo. The head was done last year. Will part out if necessary. The original GSR block from the swap is also available.
B16 Block from 99 Si:
-JE 9.0:1 pistons and rings
-H-Beam rods
-Darton Sleeves
-ABS Head Studs
-New Water Pump,New Seals, Gaskets and Timing Belt
-Skunk 2 Intake Manifold
Gsr Head
-Port and Polished
-Ferrea valvetrain, retainers and springs
Gsr Tranny
-Quaiffe LSD
-Main Shaft and rebuild done at dealer on 2004
Turbo
This started out as an F-Max kit for B-Series
-GT35R Turbo .63 AR
-FMax log type manifold
-Spearco Intercooler
-Custom 3'' Downpipe A/C Compatible
-Tial 44mm Wategate .8 and .9 springs
-Tial 50mm BOV
-MSD 6 BTM w/ StreetBlaster Coil and cap
-F.A.S.T. Engine Mangement
-Holley 65lb injectors
-APEXi AVCR
-Custom CAI
I'm sure that's not all so feel free to inquire about specifics. I also have another GT35R that was run for a few miles with a bad seal(return line in bad spot), and a Precision SC61 also with a bad seal.
Thanks for looking.
Modified by Javier23 at 10:09 PM 11/22/2006
-H-Beam rods
-Darton Sleeves
-ABS Head Studs
Gsr Head
-Port and Polished
Gsr Tranny
-Quaiffe LSD
Turbo
-GT35R Turbo .63 AR
-Tial 50mm BOV
-APEXi AVCR
-Custom CAI
Thanks for looking.
The turbo kit will fit the b18c1 or the b16 block. I swap them out when necessary.
-I will consider all offers on all parts so PM if you want the turbos.
CHEETAH
Oct 22, 2014 05:41 AM
Jay7
Northeast (Sales)
Sep 29, 2006 12:56 AM
Honduh Tooner
Jun 9, 2006 03:19 PM
