no tail,dash,or parking lights??
Old Nov 22, 2006 | 10:57 AM
92acord's Avatar
Default no tail,dash,or parking lights??
i have a 92 accord ex,my tail lights,dash lights,and front parking lights are not working,bulbs and fuses are fine..headlights and brake lights are fine..can anyone giude me in the direction of what to look for next? thanks in advance
jeff
Old Nov 22, 2006 | 11:08 AM
BlUAc's Avatar
Default Re: no tail,dash,or parking lights?? (92acord)
to double check you checked the fuse box under the hood and by the dead pedal on the driver side?
Old Nov 22, 2006 | 11:31 AM
wsuozzie's Avatar
I just had this same problem in my 92 accord. it turned out to be the switch thats in the turn signal, i had to get the whole thing replaced. mine wasnt dinging either when i left my headlights on.
Old Nov 22, 2006 | 11:33 AM
92acord's Avatar
Default Re: no tail,dash,or parking lights?? (BlUAc)
yeah checked the fuses under the hood,and driver's side kick panal(none blown).the headlight buzer(when headlights left on) is not working either.
Old Nov 22, 2006 | 11:45 AM
wsuozzie's Avatar
yep sounds like its your turn signal switch. they will likely have to replace the entire turn signal, it was about $130 to have it done. the relay inside goes bad and so the headlights get power first but dont pass it along to any of the other funcitons.
Old Nov 22, 2006 | 02:57 PM
92acord's Avatar
Default Re: no tail,dash,or parking lights?? (wsuozzie)
yeah thats what it was dude,i went to the junkyard and got one for $30..works great now..thanks for the advice.
Old Nov 23, 2006 | 07:14 AM
wsuozzie's Avatar
no problem, happy thanksgiving
Old Nov 23, 2006 | 11:14 AM
BLK Accord EX 97's Avatar
Im having the same problem my turn signals arent working and my hazard lights arent working. the dash indicators dont even light up. I took it to a machanic and they said it was my wiring harness thats rotted out which sounds kinda fishy. He said its deffiantly not the relay(fuse),etc. So what should I look for? because the mechanic quoted me 150, for soemthing that seems like a easy fix. What was the 30 dollar part you got from the junk yard. Any info on this will be greatly appericated.
Old Nov 23, 2006 | 02:20 PM
Default Re: no tail,dash,or parking lights?? (BLK Accord EX 97)
come on no one has any info for me. where is the turning signal light swith located.
Old Nov 27, 2006 | 01:41 PM
wsuozzie's Avatar
the $30 part is the turn signal switch that extends from your steering wheel that controls your signals and lights.
kap10Hook
Mar 19, 2012 10:39 AM
HondaVerno
May 1, 2010 09:08 PM
slob20ef
Aug 27, 2008 12:25 AM
hankd
Nov 24, 2004 11:08 AM
blackE_T
Oct 11, 2004 05:46 PM
