Ignition probelms on 12,9:1 (B18C6 JUN)
Old Nov 22, 2006 | 09:31 AM
Nagata-San74's Avatar
Default Ignition probelms on 12,9:1 (B18C6 JUN)
A friend has a DC2 itr with B18C6
After a full mugen phase, he bought this:
Jun stage 3 camshaft + valvetrain
EK9 pistons
-0,4mm head working
and all the suffs needed
Problem is, while tuning, @ 7500rpm, the power false down sudenly, and gets back on 8000.
A guy said it's because of the high compression engine...
Any one ? A solution, or a searching way ?
nagata-san74@hotmail.fr
Old Nov 22, 2006 | 11:09 AM
Runnerdown's Avatar
Default Re: Ignition probelms on 12,9:1 (Nagata-San74)
so he put those parts in there with no ecu change or tuning? sounds like what happens when you install parts with no tuning.
Old Nov 22, 2006 | 05:16 PM
Default Re: Ignition probelms on 12,9:1 (Runnerdown)
No !
Tuning has been made on Hondata S300
Old Nov 23, 2006 | 06:59 AM
b19coupe's Avatar
The graph would be helpful. A/F graph too. The fact that it is a high compression engine has nothing to do with a loss in power or dip at 7,500. It could be a header/exhaust dip, or it could be a tuning problem.
Old Nov 23, 2006 | 12:49 PM
1C9R9X1's Avatar
Default Re: Ignition probelms on 12,9:1 (b19coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">The graph would be helpful. A/F graph too. The fact that it is a high compression engine has nothing to do with a loss in power or dip at 7,500. It could be a header/exhaust dip, or it could be a tuning problem. </TD></TR></TABLE>a/f graph could help
Old Nov 24, 2006 | 03:27 AM
Chillinit's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote"> It could be a header/exhaust dip, </TD></TR></TABLE>
What exhaust is he running? (size)
Old Nov 24, 2006 | 03:48 AM
I'll get the graph + A/F graph asap
He's running 4-2-1 + catback Mugen Twin loop
Old Nov 28, 2006 | 09:40 AM
tintinctr74's Avatar
Default Re: (Nagata-San74)
Old Nov 28, 2006 | 10:08 AM
Jimmy's Avatar
Global Moderator
I had the same problem on my 12:5:1 CR GSR with jun 3 cams..
- What kind of cam gears does he have and what are they set at?
- What size exhaust piping is he running.. Test pipe or CAT?
PanamaVTI
23
Oct 20, 2003 10:01 AM
sqwerz
29
Aug 12, 2003 08:37 PM
ErikDaGenErik
10
Jul 22, 2003 06:46 PM
AllMotorITR
Feb 7, 2002 09:55 PM
Kelvin96GSR
Dec 2, 2001 05:42 AM
