sway bar?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow_ls »</TD></TR><TR><TD CLASS="quote">Go to passwordjdm.com and get their package with the Asr Rear sub frame brace kit W/ a 22mm or23 mm ITR sway bar. Really good set up.</TD></TR></TABLE>
I also reccomend this.
http://www.beaksproducts.com/DC_Quick_Swap.htm
What does this have that the one on passwordjdm doesn't? It is $45 more.
x2
x2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4175017 »</TD></TR><TR><TD CLASS="quote">how about the Suspension Techniques one? or the itr one is better</TD></TR></TABLE>
Honestly just stick with the ITR bar. Like I said, I reccomend the ASR/ITR combo.
I have heard that in some rare cases the beaks and other kits still tear out, but have never heard any negative comments about the ASR. And the ITR sway bar is perfectly fine and is just as good as any other brand just cheaper. And if you go bigger than an ITR you will need to upgrade the front sway bar, because you will start having slide out problems.
