600+whp goal.... Suggestion on fuel system upgrades
Old Nov 22, 2006 | 08:02 AM
Topdawgg's Avatar
Default 600+whp goal.... Suggestion on fuel system upgrades-- the debate
Ok, My goals for this winter are 400whp daily on 91 octane.. and 600+ for the track on race fuel...
Im going to have the turbo to support it, as well as the engine setup...
what im wondering is what fuel upgrades should i be looking at...
I currently have 320whp... my fuel setup is a walbro 255.. and 750cc RC's.. no fuel rail, no FPS, and no stock fuel lines..
Im wondering if i should be lookin into another pump.. maybe inline... Bosch or something..
What are you guys with these kinds of numbers running for a fuel setup...
Modified by Topdawgg at 5:07 PM 11/22/2006
Old Nov 22, 2006 | 09:37 AM
fast2camciv's Avatar
in because i have similiar goals/questions lol
Old Nov 22, 2006 | 11:45 AM
DRIVENRacing's Avatar
255 walbro, 1000cc injectors, fpr... STOCK everything else
Old Nov 22, 2006 | 11:46 AM
BoostedEG6's Avatar
Default Re: (adSPEED)
stock fuel rail will not support 600+whp. I would upgrade your pump, 1000cc injectors, FPR and a fuel rail (they arnt that expensive)
Old Nov 22, 2006 | 11:51 AM
Topdawgg's Avatar
Default Re: (BoostedEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedEG6 &raquo;</TD></TR><TR><TD CLASS="quote">stock fuel rail will not support 600+whp. I would upgrade your pump, 1000cc injectors, FPR and a fuel rail (they arnt that expensive)</TD></TR></TABLE>
i was plannin to get a FPS, fuel rail and go with the 1000cc's
i know now that im gonna need to go with a bigger pump
Old Nov 22, 2006 | 12:02 PM
atec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adSPEED &raquo;</TD></TR><TR><TD CLASS="quote">255 walbro, 1000cc injectors, fpr... STOCK everything else</TD></TR></TABLE>
+ -8an feed hoses
Old Nov 22, 2006 | 01:49 PM
billy mack's Avatar
Default Re: 600+whp goal.... Suggestion on fuel system upgrades-- the debate (Topdawgg)
get some nice aeromotive stuff.. like a fpr, and all the an fittings..
id go with a inline pump to just to be safe, .. that will run with your walboro 255
go see danny to get a fuel rail. i think they make some..
Old Nov 22, 2006 | 02:28 PM
TypeR_Turbo's Avatar
AEM Fuel Rail
AEM Regulator
AEM Fuel Filter
Walbro 255lph intank fuel pump
RC Engineering 1000cc injectors
This is all the fuel stuff we ran on our LS/VTEC and it made 615whp @21psi on race gas and 455whp @14psi on 94 pump gas.
Old Nov 22, 2006 | 05:06 PM
Topdawgg's Avatar
^^ what was your setup (besides fuel)
Old Nov 22, 2006 | 06:05 PM
714phil's Avatar
Stock fuel rail can support 600whp and so will the pump.
Old Nov 22, 2006 | 06:19 PM
tony1's Avatar
Default Re: (STD ONEpointSIX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STD ONEpointSIX &raquo;</TD></TR><TR><TD CLASS="quote">
Stock fuel rail can support 600whp and so will the pump.</TD></TR></TABLE>
This is true. I love when guys with 300hp setups think they need an upgraded fuel rail. Doesn't help matters that there's 80 people making fuel rails for hondas, they're all gonna tell you that you need one! lol
Old Nov 23, 2006 | 05:36 PM
akira712's Avatar
Default Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">
This is true. I love when guys with 300hp setups think they need an upgraded fuel rail. Doesn't help matters that there's 80 people making fuel rails for hondas, they're all gonna tell you that you need one! lol</TD></TR></TABLE>
Old Nov 23, 2006 | 06:07 PM
JoePSI's Avatar
Default Re: (eastcoast_ej)
I know the fuel rail can support 600whp but I dont think the stock pump can.
Old Nov 23, 2006 | 07:55 PM
ndogg's Avatar
Default Re: (JoePSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JoePSI &raquo;</TD></TR><TR><TD CLASS="quote">I know the fuel rail can support 600whp but I dont think the stock pump can.</TD></TR></TABLE>
he is talking about the walbro.
Old Nov 24, 2006 | 09:55 AM
JoePSI's Avatar
Default Re: (ndogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ndogg &raquo;</TD></TR><TR><TD CLASS="quote">he is talking about the walbro.</TD></TR></TABLE>
I see, I read it differently. 255 walbro has pushed 600hp without problem on my bros and friends b18c's
Old Nov 24, 2006 | 03:21 PM
morgan@synapse motorsport's Avatar
i made 613whp on walbro 255 stock lines aem reg, rail, and filter. didnt have a fuel pressure guage but im sure it was dropping. in the spring im going to upgrade my fuel system with new lines and a bigger pump. probly the bosch 044 seems to be the new things for hondas pushing the 6-700 range.
so if u can afford to do it, i would suggest sumping the tank, running something a little bigger than the walbro 255. or 2 of them. and some bigger fuel lines.
Old Nov 24, 2006 | 04:42 PM
STEEZY_EG+DC's Avatar
Default Re: (hybrdthry911)
walbro 255 in-line and intank pumps, injector driver and fpr and you should be set
Old Nov 24, 2006 | 05:15 PM
oscarmayer's Avatar
the problem isn;t that it can't support it the problem is for how long. bursting for a few moments on the stocekr is one thing, but to me knowing something about fluid dynamics from the military, i do not see it being able to sustain that rate of flow long at all. on a quick hit ok, but if you take it on the freeway i pretty certain it will lean out after a few moments of running it hard. everyone uses the excuse of it's a built honda motor it can;t take that, and you knwo what? they are right. why? if you don;t provide proper fuel support along with the tune then it won;t do it long.
on a single cam civic, i run a 8- pressir eand a -6 return. I ru a high end bosch pump and i have nothing to worrie about when it comes to fueling. I run 1000cc injectors and yes a larger fuel rail just for the added insurance.
People laugh at me and wonder why i run such large lines and stuff ona single cam.
my answer is always the same.
single, twin, quad. let you make 100+hp per cyclinder on pump fuel and see if you want to chance ruining a $12g setup over a fueling issue that could have been solved with a few hundred bucks. (engine, turbo, fuel all blown when motor goes)
i'm not saying it won't. i'm saying it won't sustain it. there's a difference. also the hotter the stuff gets the lower the pressure it prodcues. that's why I over built it. it doens;t have heating issues liek other motors and it can do what I want it too and last.
if you build to the miniums, you get the miniums. if you build tot he max, who knows how far you ca go.
whole9
Jun 21, 2007 05:42 PM
big juan
Oct 29, 2005 06:59 AM
irocdaparty85
Jun 3, 2005 08:15 PM
