so one please inlightin me !!!??
Old Nov 22, 2006 | 07:27 AM
CARflyGUY's Avatar
Default so one please inlightin me !!!??
ok the wierdest thing happens when it rains real good the inside of my car is soked on the floor and the water is coming from under the glovecompartment erea and i wanted to know what could i do for that or what could be the problem .
Old Nov 22, 2006 | 07:37 AM
97itypeR's Avatar
maybe u have a small leak somewhere that u dont know of? * duh obviously.*
i mean like maybe ur sunroof has a leak in its weather stripping?
Old Nov 22, 2006 | 07:41 AM
95 integra's Avatar
Default Re: (97itypeR)
Its most likely either the little plate by the windshield wipers leaking or the sunroof drain tube.
Old Nov 22, 2006 | 07:47 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (95 integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra &raquo;</TD></TR><TR><TD CLASS="quote">Its most likely either the little plate by the windshield wipers leaking or the sunroof drain tube.</TD></TR></TABLE>
That's only on DA Integras.
If your car is a 94-01 most likely it's either the sunroof drain tube, or you have the same problem as me, that is water coming through the frame rail. The only feasable solution I can think of is injecting expanding foam sealant up into the frame rail (because it's otherwise inaccessible), but I still haven't gotten around to trying that yet.
Old Nov 22, 2006 | 07:59 AM
crxma22's Avatar
Default Re: so one please inlightin me !!!?? (CARflyGUY)
i would get a hose and have a friend run water over seperate areas to find out where it's coming from and seal it...
Old Nov 22, 2006 | 08:10 AM
Rikter's Avatar
I would do a search, 7 post guy, as this topic is not the first time brought up.
-Rik
JDMx05
Sep 10, 2011 08:02 PM
aosix
Mar 19, 2005 10:32 AM
Hybrid 350GT
Honda S2000
13
Jan 31, 2005 09:01 PM
kwoksturr
Oct 10, 2004 05:08 PM
95GS-R
Dec 28, 2003 03:11 PM
