Climate control not working after wire tuck?
I recently tucked the drivers side light wiring on my 95 gsr, as i was driving home in the cold tonight I realized my climate control wasnt working at all it lights up and all of the buttons do as well, but it would not blow any air
when I did my wire tuck I had cut and blocked off all the wires for my ABS motor that has been removed
Is there and ground or singal wire that I may have cut while doing the wire tuck that would cause my climate control to not work?
all help is appreciated
, winter is coming up fast and I need my defrosters to work asap
I'm still in the process of tucking my passenger side harness and removing my ABS. I took out all the ABS crap in the engine bay and took off all the wire loom on the passenger side harness. I cut all the wires for the ABS just like you did after looking through the wiring diagram. I only cut the wires off where they come through the firewall as I didn't want to remove that whole harness. I didn't see any part of the ABS harness that would be part of the climate control, of course I haven't had a chance to hook up my battery and see if my blower still works
Maybe I'll check that out tomorrow and I'll let you know my results. Otherwise I'd like to hear if you figure out anything.
for sure, i would appreciate that
, I have a feeling there may have been a thick ground wire for the heater core motor that I snipped thinking it was part of the abs
anyone else have any input?
, I have a feeling there may have been a thick ground wire for the heater core motor that I snipped thinking it was part of the absanyone else have any input?
I just checked all the bottons and the open and close the vents to get the correct flow of that button
it is only the actual air motor that is not working
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2 Mang »</TD></TR><TR><TD CLASS="quote">anyone have a wiring diagram or anything for the heater/AC fan?</TD></TR></TABLE>
The Helm has a diagram. Search google for "hondahookup manuals" and download.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator »</TD></TR><TR><TD CLASS="quote">
I searched through before, the diagram they had was for a prelude but I believe it may be a ground that I cut
</TD></TR></TABLE>I searched through before, the diagram they had was for a prelude but I believe it may be a ground that I cut
Well, I finally had a chance to hook up my battery and try out my heater blower motor and it's working fine. Maybe you cut something that I didn't or you have some other problem. On mine, I cut everything that had an orange plug on the end and I also cut the 2 grounds for the ABS controller. Good luck with trying to fix it.
