need help removing clutch and trans housing apart.
i need help removing both the clutch and trans housing apart but it would only come off an inch and it stops from there. i dont know what else to remove, theres basically no more bolts to remove.
A. You really shouldn't be doing this without a shop manual.
B. There's a snap ring you need to remove under the 32mm pipe plug to seperate the halves.
C. I hope you've removed the detent *****.
D. Get a shop manual.
