Suspension & Brakes Theory, alignment, spring rates....
EG lowering springs on an ef, yes?
Old Nov 21, 2006 | 10:32 PM
Metal Head's Avatar
Default EG lowering springs on an ef, yes?
Just wanted to ask if I can used EG(92-95) civic springs on a 88-91 strut?
I have the 89-91 strut in my EG and wanna use my 92-95 EG Nuespeed springs, yes or no?
Old Nov 22, 2006 | 08:40 AM
Tyson's Avatar
Default Re: EG lowering springs on an ef, yes? (Metal Head)
no.
itll fit, but ride heights will be off.
Old Nov 22, 2006 | 10:36 AM
FalkenSiR's Avatar
EF shocks are slightly shorter than EGs, so you will be more likely to bottom out. Ride height will be what it should be.
Ride height will differ if you have mismatched springs, but you have springs designed for your car, so you will be fine.
Old Nov 24, 2006 | 08:09 PM
Metal Head's Avatar
Default Re: EG lowering springs on an ef, yes? (J.MONEY)
anyone got a reason why some 92-95 peeps put in 89-91 struts in the 92-95 cars?
Old Nov 25, 2006 | 09:57 AM
Tyson's Avatar
ive never heard of any eg owner using ef shocks, but the ef shock is a bit shorter that would give more shock travel. just a bit.
88HATCH(:
Suspension & Brakes
Jan 31, 2012 01:33 AM
Mr. DeOro
Suspension & Brakes
Aug 6, 2010 06:07 AM
