Eagle rods VS rev
Old Nov 21, 2006 | 08:02 PM
Forrest Gump 9's Avatar
Default Eagle rods VS rev
Realisticly, what is the safe rev on the Eagle rods? I know, I know, I should only rev up to where the engine quit making power, but I've heard so many horrow stories about Eagle rods. So it kinda worry me. My set up is just a B20/Vtec with Eagle rods and CP pistons. Rev limiter set at 8500 rpm. IS it safe? I want to upgrade the cams and rev higher, but the Eagle rods myth haunt me.
Old Nov 22, 2006 | 05:11 AM
d16dcoe45's Avatar
Default Re: Eagle rods VS rev (Turbo9Nut)
What "horror" stories?
Old Nov 22, 2006 | 05:17 AM
D-Rob's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo9Nut &raquo;</TD></TR><TR><TD CLASS="quote">Realisticly, what is the safe rev on the Eagle rods? I know, I know, I should only rev up to where the engine quit making power, but I've heard so many horrow stories about Eagle rods. So it kinda worry me. My set up is just a B20/Vtec with Eagle rods and CP pistons. Rev limiter set at 8500 rpm. IS it safe? I want to upgrade the cams and rev higher, but the Eagle rods myth haunt me. </TD></TR></TABLE>
With aftermarket rods, why should you fear to go above a stock Honda's normal operating range? (For example, the ITR's stock rev-limit is 8600 RPM)
I take my LSVTEC to 9000 RPM on stock rods with ARP bolts.
Old Nov 22, 2006 | 01:55 PM
Default Re: Eagle rods VS rev (d16dcoe45)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16dcoe45 &raquo;</TD></TR><TR><TD CLASS="quote">What "horror" stories? </TD></TR></TABLE>
LOL. Rods hanging out the block. Piston 100 ft from the car,.....
So it's ok to go 9+Krpm on Eagle rods??
Old Nov 22, 2006 | 03:59 PM
d16dcoe45's Avatar
Eagles are very tough--just being an H-Beam design makes them quite strong--alot of material, not exactly lightweight. Also have really good bolts.
Old Nov 22, 2006 | 06:50 PM
nonvtecD's Avatar
The only way a forged rod would let go is if the bolts do. In a NA engine why would you use H beams?
Shartek
Feb 16, 2008 01:49 PM
xQB21x
16
Nov 26, 2006 04:14 AM
marcussmith26
Dec 13, 2005 07:45 AM
teg92
Sep 6, 2002 08:53 PM
