Do I really need a spring compressor?
I'm installing coilovers on my coupe and I can't find one to rent in town so can I get away without using one?
I'm pretty sure I did a spring replacement in my old CRX without using one but that was a long time ago....and I now have 95 coupe
What do you guys think?
I know this is really bad to say but.... I used to always just stick the shock in between two tires and then undo the bolt. Just make sure your hand is not in the way! Invest in a spring compresser though its alot faster and much safer.
put ur damn foot on the spring.. and just take the bolt of real slow.. it will be fine.. dangerous.. but will work.. i done it on a few cars i done for people..
go to local hardware store and get mini ratchet straps. they work great , but i just stand on the spring as well , take nut off , little pop , nothing major. easy to get lowering springs or coilovers back on.
go to sears buy one, use it, and take it back. I have done this before ... just say it does work how you wanted or you got another one thats better there like 50 dollers or so but you will get that money back anyways soo good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oneslowstd »</TD></TR><TR><TD CLASS="quote">I know this is really bad to say but.... I used to always just stick the shock in between two tires and then undo the bolt. Just make sure your hand is not in the way! Invest in a spring compresser though its alot faster and much safer. </TD></TR></TABLE>
That's what I do
That's what I do
how hard is it to do it the safe way and go rent the tool? Unless u got lowering springs, i would do it right....whatever works for you
Good luck and be safe.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeadEnd9009 »</TD></TR><TR><TD CLASS="quote">how hard is it to do it the safe way and go rent the tool? Unless u got lowering springs, i would do it right....whatever works for you
Good luck and be safe.</TD></TR></TABLE>
The spring compressors you rent suck. They're just two giant bolts with some hooks on them.
Place foot on BOTTOM of spring and shop rag over the end nut to prevent losing it. Point against wall and loosen. It will seem violent at first, but it's really more noise than danger.
go rent the 10 dollar tool from a damn parts store and call it a day.. my old boss lost 2 fingers doing it the "ghetto way" when he was younger. Why risk getting hurt, do you guys realize how much pressure that spring is under?
to bad advise.. good luck with your tires, shop rags, and using your foot.. oh and i cant foget to compliment clayne who's wise words were "point it against a wall"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdeemseerx »</TD></TR><TR><TD CLASS="quote">go rent the 10 dollar tool from a damn parts store and call it a day.. my old boss lost 2 fingers doing it the "ghetto way" when he was younger. Why risk getting hurt, do you guys realize how much pressure that spring is under?
to bad advise.. good luck with your tires, shop rags, and using your foot.. oh and i cant foget to compliment clayne who's wise words were "point it against a wall"</TD></TR></TABLE>
I know people that lose fingers in kitchens. Doesn't stop me from being a sous chef in a high volume establishment. *shrug*
to bad advise.. good luck with your tires, shop rags, and using your foot.. oh and i cant foget to compliment clayne who's wise words were "point it against a wall"</TD></TR></TABLE>I know people that lose fingers in kitchens. Doesn't stop me from being a sous chef in a high volume establishment. *shrug*
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">I know people that lose fingers in kitchens. Doesn't stop me from being a sous chef in a high volume establishment. *shrug*</TD></TR></TABLE>
I've never even came close to losing a finger or anything dangerous removing springs the "ghetto" way. I honestly don't know how people get in those situations.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clayne »</TD></TR><TR><TD CLASS="quote">I've never even came close to losing a finger or anything dangerous removing springs the "ghetto" way. I honestly don't know how people get in those situations.</TD></TR></TABLE>
bigger springs off of bigger car's that are more compressed then a civic spring...i can fit a civic spring in my back pocket.
OK guys, thanks for all the input
And like I said in the original post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wheelmanbg »</TD></TR><TR><TD CLASS="quote">I can't find one to rent in town</TD></TR></TABLE>
so if I wanted to use one I'd have to buy it....just to use it this one time, so it doesn't seem worth it to me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wheelmanbg »</TD></TR><TR><TD CLASS="quote">OK guys, thanks for all the input
so if I wanted to use one I'd have to buy it....just to use it this one time, so it doesn't seem worth it to me</TD></TR></TABLE>
There's not an Autozone or O'Reilly's anywhere?
If you don't want to use it then don't...
seeeya04
Suspension & Brakes
10
Jan 16, 2005 06:24 PM
Chip398193
18
Jul 8, 2003 04:57 AM
