While your up north shoveling snow, were down south tracking our cars. 56k warning
Old Nov 21, 2006 | 05:48 PM
Dave_B's Avatar
Default While your up north shoveling snow, were down south tracking our cars. 56k warning
Well fella's I got a chance to take the pile back out again to Sebring. Car felt great and I couldn't have asked for a nicer day. Was in the low 60's in the morning and warmed up to mid 70's for the high. Nice and sunny, typical winter day here in Florida. So I made some changes for this event again. First up I swaped out the stock 22mm rear sway bar in light of a 23mm JDM sway bar. I also added 2 clicks stiffer for the sussy and lastly I changed the seating position again. Lowered the seat about another half inch and also moved it forward another 2 inches. I still need to shim the column down about an inch and I think it will be perfect.
So it was a good and bad day. First session started out and for some reason the car just didn't feel right. It was sorta fine in the corners (getting point bys) but then I came out of T17 onto the front straight and struggled to pass cars. Well, that's odd. Turns out the Vtec wasn't coming on at all. I knew the oil level was fine and I was on a straight so oil deprivation wasn't an issue. Couple of laps later going around the carosel (sp) it decided to kick in while I was tracking out. Very interesting time for it to come back needless to say. Still though, during that session it wouldn't stay in Vtec past 7800 RPM. Odd I thought. I finished out the session and started to look at it. Turns out to be a bad connection to the VSS. I removed and repluged it in a few times to get a good solid connnection and all was good for the rest of the day as far as Vtec is concerned but the spedo was still jumping around. Second session was fantastic. I finally got my braking down in a few places enough to get a slight wiggle in the rear under hard braking. Third session was going great too until the last lap of the session. I came out of the hairpin in T7, went through 8 and 9 and into 10a the car lost power and sounded odd. I instantly went into panic mode thinking to myself this is only the second time I've had the car out, please don't be something major. I pulled to the side of the track and shut the car down. Sat for a few moments as everyone else finished up their cool down laps and proceeded to try to fire the car up again. She started but was shaking pretty bad and still didn't quite sound right. So the corner worked signaled the tow truck and off we went, being towed back to our spot was the worst feeling ever. I was having such a great day up until that point. We parked the car and popped the hood. Me not being in the right state of mind can't think of anything other than possibly a bent valve. Turns out that a MSD plug wire had backed off on the dizzy side. Thanks to Dave-ROR pointing that out, I wasn't even thinking about that. He plugs it back on and I fired up the car. All was once again well. That didn't last to long, turns out I may be replacing the brake booster before the next outting.
I have to say, going out for the second time in the car was a great experience. No more nervousness of being out for the first time. I knew what to expect and I knew the track layout and the lines. I ended up improving my lap times by 7 seconds according to our stop watch (yeah, not official but close enough) Now I'm turning sub 3 minute lap times (Sebring is 3.7 miles 17 turns) I'm working on a few new things, T17 instead of going around in 4th, I'm now going in 3rd for about 2k RPM before I shift during track out. Turning in a little bit later on T1 (wow what a difference that makes, especially since there's a wall on the inside of that turn about 1 foot from the rumble strip), also working on the carosel. Apparently I wasn't out far enough the last time out. Now I'm much faster going around it. Lastly I was working on braking. Learning my braking points per corner and really working the spec VR's. If your not smelling the brakes, your not using them right.
Recap of the day:
First session I had the VSS issue that sorta worked itself out by the end of the session, came in and reconnected it and all is good.
Second session was almost to good to be true. Not a single hiccup.
Third session though, the MSD plug wire issue made my heart sink.
What I learned this time out is as follows:
Turning in later is sometimes better than turning in early. At least at Sebring, there are a lot of corners that you can carry more speed this way.
MSD plug wires are teh suckzor!!! I'll never use them again on anything I ever own. Back to stock for me!!!
The A-pillar cage bar on the drivers side really needs to be closer to the cars A-pillar. I really like how DavidNYC has his done. I'm going to be talking to the fabricator to see what we can do about that.
Question for you guys though before the pics, with the Azenis 615's what hot and cold tire pressure are you running? At the end of the day I was up to 39 PSI all the way around in them. Thoughts?
Well enough with all the rambling, on with the pics as they say. There were a few nice cars out there on Sunday.
I wish I could have seen this DB9 on track more than the parade laps.
I've only seen a few of these. This is for you Pat!!!
Oh how I'd love to have a GT3!!!
Always makes you feel good when you get a point by from one of these.
Wish this one would have been out there too.
The chick driving this SC mustang was fast as hell!!!
Dave-ROR's pile of crap
My pile parked
This was the only car on track louder than mine.
My buddy out on the parade lap with mah old man driving.
I don't think I noticed it as much last time out, but this time coming around the back section there was a plane landing heading in my direction maybe 200 yards to my left.
And finally on with the pics of me on track. I had a blast!!! Thanks again to PIC for all the support you have given me, you guys rock.
The timing tower.
Turning into T1
Little early turn in on T7
One of my favorite pics from the day. Thanks ROR.
Not sure which corner this was. Looks like the back section around 14-15
This is a fun section here. This is the part of the track that I never thought I'd be going as fast as I am.
No really, the planes are right there.
Going round the carosel.
Not sure where this is either
Looks like T3
Mid turn in, in T1
Looks like the beginning of the carosel.
Not quite sure what I was looking at here.
Before turn in at T1
Coming under the Audi bridge.
Modified by Dave_B at 8:59 AM 11/22/2006
Old Nov 21, 2006 | 05:50 PM
Lifter2012's Avatar
Default Re: While your up north shoveling snow, were down south tracking our cars. 56k warning (Dave_B)
are these pics small enough bitch?
Old Nov 21, 2006 | 05:53 PM
Hooch'n's Avatar
looks good, like i've said before.......can't wait to drive sebring. Looks like great weather.
Old Nov 21, 2006 | 06:06 PM
Dave_B's Avatar
Default Re: While your up north shoveling snow, were down south tracking our cars. 56k warning (Lifter2012)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lifter2012 &raquo;</TD></TR><TR><TD CLASS="quote">are these pics small enough bitch? </TD></TR></TABLE>
Talk to Dave and Craig. I UL'd them at 800 x 600
Old Nov 21, 2006 | 06:13 PM
Willard's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B &raquo;</TD></TR><TR><TD CLASS="quote">If your not smelling the brakes, your not using them right.
I don't smell my brakes.... only the car that is in front of me.
Glad you had fun at the event.
Old Nov 21, 2006 | 06:23 PM
PrinceAli132's Avatar
Looks like you had a great weekend. I really wish I made it out, hopefully I'll be at the next one.
Ali
Old Nov 21, 2006 | 06:59 PM
Erik95LS's Avatar
Default Re: While your up north shoveling snow, were down south tracking our cars. 56k warning (PrinceAli13
Looks like fun Dave. Whats your concern about teh booster?
Old Nov 21, 2006 | 07:02 PM
BlueR's Avatar
bah, i'll check back when i can actually see the pics
Old Nov 21, 2006 | 07:20 PM
coolhandluke's Avatar
Looks like fun Dave
Old Nov 21, 2006 | 07:23 PM
Doespike's Avatar
Looks like fun, now swap out those wires, fix the speedo and booster and get back out there!
Old Nov 21, 2006 | 07:56 PM
KYLE.'s Avatar
Default Re: While your up north shoveling snow, were down south tracking our cars. 56k warning (Doespike)
looks like a good time. p.s. snow hasn't came down yet..but it will
Old Nov 21, 2006 | 08:14 PM
VTEC_Club's Avatar
Default Re: While your up north shoveling snow, were down south tracking our cars. 56k warning (KyLe V)
Love the title
Old Nov 21, 2006 | 09:05 PM
white rocket's Avatar
As soon as my A.D.D. calmes down I'll actually READ all that writing of yours . Nice pics though.
Old Nov 21, 2006 | 10:01 PM
GO-FIGHT-KILL's Avatar
Looks fun as Hell! Man I can't wait until VIR.
Old Nov 21, 2006 | 10:38 PM
neo_'s Avatar
Default Re: (GO-FIGHT-KILL)
weaksauce
Old Nov 21, 2006 | 10:50 PM
^ How the F*ck haven't you been banned yet?
Old Nov 21, 2006 | 10:55 PM
an2ny888's Avatar
fyi the stock ignition wires have backed out on my friends car as well
Old Nov 22, 2006 | 03:55 AM
RTW DC2R's Avatar
fock MSD!!!
39psi sounds kinda high?
glad u kept the shiny side up Dave remind me to bring my magnifying glass next time for the pics though.
Old Nov 22, 2006 | 04:18 AM
Dave_B's Avatar
Damnit, how small are the pics for you guys? I'll see if I can re-upload them again but I UL'd them at 800x600. Damn WTDR... I'll call Dave or Craig and see whats up if after another UL it doesn't work.
As for the wires, Mr. Tran made a suggestion but I'll still put the stock ones back on and do just that very suggestion of zip tying the boot at the dizzy.
Edit: Trying another size for the pics.
Weird, if I UL them at 1024x768 they are way huge, at 800x600 they are way small. What gives? Guess I'll redo them all for 1024, bigger is better than smaller right?
Er. This makes no damn sense!!! I guess WTDR has file size restrictions now.
Modified by Dave_B at 8:28 AM 11/22/2006
Modified by Dave_B at 8:29 AM 11/22/2006
Modified by Dave_B at 8:30 AM 11/22/2006
Old Nov 22, 2006 | 04:28 AM
Bradstard's Avatar
Nice thumbnails
Glad to see you got the car out on the track!
Old Nov 22, 2006 | 04:31 AM
RTW DC2R's Avatar
Default Re: While your up north shoveling snow, were down south tracking our cars. 56k warning (Bradstard)
interweb pixor sizing &gt; j00
Old Nov 22, 2006 | 04:40 AM
Jon D's Avatar
Default Re: While your up north shoveling snow, were down south tracking our cars. 56k warning (RTW DC2R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2R &raquo;</TD></TR><TR><TD CLASS="quote">interweb pixor sizing &gt; j00</TD></TR></TABLE>
huhuhu.... jeah j00 pixies suck Dave . We still lub j00 though.
Old Nov 22, 2006 | 04:43 AM
Dave_B's Avatar
Default Re: While your up north shoveling snow, were down south tracking our cars. 56k warning (Jon D)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jon D &raquo;</TD></TR><TR><TD CLASS="quote">
huhuhu.... jeah j00 pixies suck Dave . We still lub j00 though. </TD></TR></TABLE>
Mr. Bradstard is going to take care of it for me, I just emailed him the pics real quick so he can UL them somewhere else. I need to advise the WTDR boys of the new issue since the upgrade. Thanks Brad.
Old Nov 22, 2006 | 04:50 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KyLe V &raquo;</TD></TR><TR><TD CLASS="quote">p.s. snow hasn't came down yet..but it will </TD></TR></TABLE>
Yup. It's in the fifties all this week around here.
I move the winter tires to the garage in the fall, ready to put them on when the snow comes. Usually that happens around the middle of December (when I go to VIR with Chin Motorsports). Not now. (Not usually, anyway.)
Old Nov 22, 2006 | 04:55 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dave_B &raquo;</TD></TR><TR><TD CLASS="quote">being towed back to our spot was the worst feeling ever.</TD></TR></TABLE>
It's not as bad as being towed 200+ miles home. And paying for it. BTDT...
