RSX TYPE-S tranny victim #80054645123789764
Old Nov 21, 2006 | 05:15 PM
willyboyK20's Avatar
Default RSX TYPE-S tranny victim #80054645123789764
S#%&#.........
I was driving normally tonite, no speeding, no nothing
Came to a stop light, light turned green, started off in 1st and then when I went to
shift into 2nd...............nothing, clutch all the way in nothing........
Drove home in 1st, 3rd and 5th. I don't have 2nd, 4th, 6th or reverse.
Rass!!!, Bombaclat!!!, fucre!!!!
I'm gonna call Acura when I get back from turkey vacation. Does anyone know if the factory warranty was extended because of tranny problems. For the record mine is an '02 w/ 57,778miles and the mods are:
CAI
2.5 inch catless custom exhaust
tein springs
Competion Clutch stage 2 w/Act Prolite flywheel (I hope they dont give me **** about this but they probably will)
Funny enough when i first bought the car I went to acura to see if any work was done on it and the clutch was previously changed at 30,000 miles under warranty I thought the clutch was a wear item.
Old Nov 21, 2006 | 05:40 PM
swollen_cu's Avatar
Default Re: RSX TYPE-S tranny victim #80054645123789764 (willyboyK20)
well if you dont have 2nd 4th or 6th or Reverse, it migh tbe a broken shifter cable. cause its kinda odd to have all those geras go out at the same time. but most definately its the shifter cable. maybe the cotter pin came out.
Old Nov 21, 2006 | 05:47 PM
Default Re: RSX TYPE-S tranny victim #80054645123789764 (swollen_cu)
I'm gonna go check that right now
thanks for the input
**I'll be back** shwarzengger voice
Old Nov 21, 2006 | 05:55 PM
shifter cables are in place
cotter pins are alittle loose but still in place
Both cables are still connected, I'm even able to move the cable closest to the engine back and forth
any other ideas??
Old Nov 21, 2006 | 07:14 PM
swollen_cu's Avatar
check the ones in the engine bay too that connect to the shifter linkage on the trans
Old Nov 21, 2006 | 07:37 PM
hondafrk505's Avatar
hmmm it could be your synchros.. but take it to the dealership if you have warrenty.
Old Nov 21, 2006 | 10:32 PM
DC5ITR329's Avatar
before you start blaming the car for not working right or saying that tranny is broken. check your CAI. it could be hitting the hammer that swings when you change into 2nd, 4th, and 6th. that is what it sounds like to me. if it's not that then let us know what it is.
Old Nov 22, 2006 | 04:10 PM
swollen_cu's Avatar
Default Re: RSX TYPE-S tranny victim #80054645123789764 (DC5ITR329)
^ +1
Old Nov 22, 2006 | 07:07 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC5ITR329 &raquo;</TD></TR><TR><TD CLASS="quote">before you start blaming the car for not working right or saying that tranny is broken. check your CAI. it could be hitting the hammer that swings when you change into 2nd, 4th, and 6th. that is what it sounds like to me. if it's not that then let us know what it is.</TD></TR></TABLE>
I'll check that when i get back from D.C.
I hope its as simple as that cause I got no warranty anymore (57,770)
Old Nov 22, 2006 | 08:20 PM
dc5tegk20's Avatar
yeah dude ive heard alot of people with CAI have this same problem check it out
Old Nov 22, 2006 | 09:32 PM
eMpAtHy's Avatar
because u had problems with ur transmission and u upgraded ur clutch and flywheel, they will deny the warranty job because a tranny job isnt cheap
Old Nov 25, 2006 | 05:48 AM
Default Re: RSX TYPE-S tranny victim #80054645123789764 (eMpAtHy)
Well I checked under the car and the shifter console and the cables are not tied up and the cables doesn't hit the CAI
SO it looks like I going to start of the new year with some serious CC debt.
Yay!!!!!!!!!!!!!
Old Nov 25, 2006 | 07:23 AM
v-attack's Avatar
From: First in Flight, Type Rs of East Coast, NC, FL
PM sent
Old Nov 27, 2006 | 06:06 AM
eezeekial's Avatar
they acura dealerships down here will give you major **** for not having them install the clutch...hopefully yours wont
Old Nov 28, 2006 | 01:51 AM
miztahsparklez's Avatar
1st 3rd 5th extend the shift linkage farthest towards your cai, its not that its not getting full travel, because you would feel it "catching" on your intake. 2nd, 4th, etc.. go back the other way, so that cant be it.
and you did check both inside the engine bay and under the center console right? have someone shift inside the car while you watch the linkage move 1st, 3rd, 5th, then see what happens for 2nd 4th and 6th. if the linkage doesnt move, its between the cable, and shifter. if it does move, see if its moving enough.
does your gears engage smoothly? or do they feel notchy? could be your clutch pedal position adjustment. too much can force too much clutch fluid into the master/slave cylinder and cause leaks. too little wont allow the clutch fork to move all the way to disengage.
if you hear your car making grinding noises when it drives around, or even at idle.. that means yes your synchros or something is messed up bad... unfortunately i had 2nd gear disappear while coming home much like you... but all geras worked for me. but i had to hear every tooth break off of my transmission when i drove it that two blocks to my house.
DarkRattle
Transmission & Drivetrain
Jun 19, 2017 02:16 AM
ep3 type-s
Aug 1, 2007 06:05 PM
02 Civic SI 865
Dec 16, 2006 06:44 AM
GreenBean
Apr 23, 2004 10:52 AM
Tweakmeister
Apr 30, 2002 11:59 PM
